SnowTrac Hunter
Made a day trip to the cabin to verify dimensions for front outer drive sprockets. (Recorded dimensions in separate thread.)
Discovered that large rear rim on drivers side was cracked and broken badly. Need to replace and purchase a spare. Most likely was caused by PO replacing studs with bolts and holes wallowed out by loose bolts.
Does any one know of replacement rims and tires? Can I swap the hub to a 6 hole and a standard wheel?
Thanks,
Joe
Thanks,
Joe
