Times like these you find out who your friends are...
TalleyHo
Last weekend had some high school buddies of mine come up for a little cruisin around the mountain. We ended up doing more digging than anything else. Got message out to the others on the mountain and had a good showing of help show up with shovels in trade for open bar later... Fair deal in my mind.
Learned a bit more about our snow in this area. Had about 12" of fresh stuff over rained on and frozen layer then powder again. Front right track went through and under the crunchy stuff and wedged down deep. The front tip of the track was down several feet.
Ended up winching up and back after lots of digging. Then packing in front of tracks just like what you would do on sled. The other interesting thing was that once the machine got to soil it was muddy and slick. We had fallen into a bit of a runoff under the snow on top of every thing else.
mlang2005
Man you guys did a lot of digging!
Where was this?
Did you guys consider chaining a log across each set tracks?
I really dig this blue color on a tucker
TalleyHo
Where was this?
It was on the snow mobile trail at Camp Oljato on Huntington Lake, Ca.
As far as the chaining log goes we did not consider. One track on each drive was packed with snow and the other spinning freely. Thinking now about this I’m not sure how that would have worked without tearing up belts.
Embarrassed as I am to admit, I was a little too confident with the winches I have (of which I snapped the cable on the front 15k trying to pull forward) and the “slight” oversight of forgetting the shovels at the cabin.
Thanks on the color. I kinda dig it too. Pun intended.
GlacierSean
Sorry if your already aware of this but a tow strap, shackle and snatch block are just as important as the winch. It will keep you from snapping your winch cable, ruining the gears in the winch and damaging the tree. Oh and most importantly it will allow you to winch out without so much digging( 2 snatch blocks would have gotten you to 45k-60k pulling power with your 15k winch). I also really like the blue on a Tucker. Have fun on your future adventures.
TalleyHo
No worries on the advice. The snatch block is what saved our butt pulling us back. I didn’t have a winch point close enough to use on the front end.
Thanks again on the color. [emoji1303]
mlang2005
The log trick probably best left to the two track cats I’d guess.
At least you weren’t 20 miles up and over the mountain haha. Don’t feel bad Ive been there.....deep snowpack and warm sunny days.... I’ve found that if it’s really bad just clean out the tracks and wait for the sun to go down and drive right out.
You guys must of picked up all the blue cans before snapping the last photos ��.
Northcoast
I know that area well,my first snowcat trip (MANY YEARS AGO!) was in an older sprite going to Florence lake. Not a good choice after a heavy snow without a blade (a lot of digging to make a flat spot for the uphill track). Tranny broke on the way out,which made for an overnight snow camp and a looong day of snow shoeing. Had to wait for summer to recover the cat. My next cat had a blade,front and rear winch recievers,lots of winch line. (along with a lot of other stuff for an overnighter). Love the blue paint and I think the model 1544 are a great machine.
TalleyHo
That’s awesome! Florence Lake! I thought I was cool making it around Huntington. [emoji1787] I am pretty certain I would have to take quite a bit of extra fuel.
redsqwrl
Well now you have the knowledge and skill to make your next outing more able.
KSA.
Air lockers are the best and worst thing you can do to a tucker..... but man would I love to have a couple.
sno-drifter
Did you access Florence Lake via Kaiser Pass road Northcoast? Damn, that is some road. Bad enough in the summer.
nikos
Ktalley Learned a bit more about our snow in this area. Had about 12" of fresh stuff over rained on and frozen layer then powder again. Front right track went through and under the crunchy stuff and wedged down deep. The front tip of the track was down several feet.
The Photo with the Blue Tucker
Nikos
Northcoast
Yes,we took the road from Huntington Lake over Kaiser pass. I've been back a couple of times since ,only now I have a tucker with a blade. No digging (or breakdowns)!
tatman
Detroit locker in the back and a ARP air locker in the front. Then the traction track will not be trying to pull the dead track threw the snow. However with all four locked you have to be kind to your drive train. Transfer case and drive shafts. Not so good for sidehilling ether.
