Imp LED Halo with LED HID Headlights
rodre
I threw a set of these on, in amber of course, they look good:
https://www.octanelighting.com/prod...alogen-li-set-of-4-5-3-4-amber-cob-60w-blue-4
Those are the housings with a halogen bulb. To go to LED HID you need these bulbs:
https://www.octanelighting.com/prod...ob-360-led-white-headlightpair-3rd-gen-led-h4
You need those exact bulbs because all others are too tall to fit in the headlight buckets.
I plan on running the Amber halos as DRL to let the sledders know I'm coming, just need to hook them into the dash panel to turn on when the engine is running.
redsqwrl
I put a set on a A model Spryte. I also have the octane cheapy reflectors on the 1642 in the clowder 2019. One of those photos shows them lit up.
careful if you put HID in the octane reflectors, not all of them are Metal housings.
LED is a non issue as the bulb and spectrum of light is not much heat in the reflector.
HID is a different animal. I messed with the focal points a bit to pattern the luminaire.
I am happy, Led is not my thing, I like the color and up close amount of light. But I need to reach out a bit when searching for reflectors on the trails or land marks on lakes. LED are ok but HID are great. (if focused properly)
JesseHiserp
Thank you for your advice. I'm just starting to figure this out, and I would like to avoid most of the mistakes because I don't have money for new materials for LEDs. I decided to make myself smart strip lights, like the one I recently bought for a great price. The bottom line is that this LED strip can be switched using WiFi and voice, and I don't think I have the knowledge and the ability to do something like that on my own right now. So I decided to simplify everything to the switch and hope to succeed. Anyway, I'll know where to turn with this question now.
