Bombardier Muskeg wiring diagram
DynatracGuy
I have an older 70's (?) Muskeg. I have the parts manual but no wiring diagram. The one in the parts manual is useless. I could trace it out if I had to, but weather is so cold right now. I found that the starter button is always wired to power, even with the key switch in the off position. Is there any reason for this? Maybe someone modified it, but wiring looks original. Seems like an invitation for trouble as I will be leaving it in public parking areas at times.
MNoutdoors RIP
Gas, flat head 6, double D tracks, key switch for ignition, separate push button switch for starter, heater switch gone as is original heater. I got an underdash one from JCWhitney that should work well.
I Will scan one for you, does not sound fatory what you have going on in yours
MNoutdoors RIP
here you go.....
aulen2002
For future reference - that looks virtually identical (excluding hour meter and 1 speed vs. 2 speed heater fan motor) to the original dash configuration and wiring of my J5.
