Alaska Jay
Last weekend I bought a 67 ST-4. It's in pretty good shape, body wise. But has a ton of shitty wiring and 50 years worth of added on unnecessary bullcrap that has got to go. It runs fine, but the transmission worries me. It popped out of reverse a few times during the only test run I've done. Once I figured out the gear positioning, all the forward gears seem to operate ok, but I just don't feel a positive engagement when I shift gears. It's going to get swapped with a freshly rebuilt tranny with a 4.375 gear ratio from Aircooled.net. I asked them for a 5 speed, but they said it would run about $5000! No thanks..
The engine is getting swapped with a mid 90s 2.5 Subaru engine. I may have chose a different one, but I couldn't pass the deal up. I got a complete (except the rear diff) Forester which was involved in a rollover for $150.
I don't see any braking system in the rig. There's a brake pedal, but it's locked solid with the clutch pedal and I don't see any braking mechanisms under the hood (although, I didn't spend a ton of time looking so far). I have found 2 cable conduits that pass over the frame, midway back under the cabin. They look like e-brake cables, but again, I didn't see where they connect to up front. Whatever, I'll install brakes as well, if there are none.
All wiring is getting replaced. Dash is getting replaced with all new gauges. Gas tank and battery are getting mounted outside. All rivets are getting replaced and body seams getting reinforced with aluminum doubler plates. Sliding fabric too is getting replaced with a sheet of aluminum. However, I'll probably find a sunroof to install. Interior is getting stripped and spray-foamed (to dampen all the noise), then coated with bedliner. In the end, I'll have 2 forward facing seats up front and all cargo space behind. Maybe possibly have seating options in the rear.
Anyway, I'm just getting underway. I've got parts on order and have managed to do lots of stripping in the interior. I'll attach some pics.
