Go Back   Forums Forums - Off Topic Forum FUN > Off Topic Forums > Ham Radio Forum
Ham Radio Forum A place for ham radio enthusiasts to talk shop
Reply
Thread Tools Search this Thread Display Modes
  #41
Old 11-25-2014, 08:16 PM
Snowtrac Nome's Avatar
Default Re: More QRP...
I've looked at screw driver models even talked with some of the manufactures and they all are concerned about the environment I will be using them in
__________________
Don
1962 st-4
KL2ZF
  #42
Old 11-25-2014, 08:33 PM
JEV's Avatar
JEV JEV is offline
Mr. Congeniality
JEV has a spectacular aura aboutJEV has a spectacular aura aboutJEV has a spectacular aura about
Quote:
Originally Posted by Snowtrac Nome View Post
Ki0ho any ideas about a multi band hf antenna for brutis I have enough room for my ts 140 in it
Here are a few ideas for you. http://qrznow.com/70-wire-antenas-ideas/
__________________
Time to go fishin'
"I'm no gynecologist, but I'd be happy to take a look..."
  #43
Old 11-26-2014, 12:15 AM
those would be nice for a stationary set up I'm looking for a mobile idea. what seems to be sticking with mew right now is going to be a 102 inch whip ,with a auto tuner.mount the tuner at the back of the cab with a short run of coax to the antenna that will make for about the best hands free works in icy conditions I can find right now. I don't see much else out the other options are essentialy the same, ie the screw drivers
__________________
Don
1962 st-4
KL2ZF
  #44
Old 11-26-2014, 05:08 PM
squerly's Avatar
squerly squerly is offline
Supported Ben Carson
squerly will become famous soon enoughsquerly will become famous soon enough
congratulations now pick up a fm radio and find a node in your area steerit to the Alaska reflector and give a shout out my radio has been on all day
OK, I'm working on it. By any chance, do you have a 2 meter repeater close by?
  #45
Old 11-26-2014, 05:33 PM
Quote:
yes I do have a repeater system here my node is simplex and I leave it connected to the Alaska reflector. a reflector is just a hub that lets multiple nodes communicate. so once you have found a node in your area either simplex or connected to a repeater it's a matter of disconnecting with a 73 command than re connecting with a 9070 command. the best way to find a node in your area is go to the irlp web site do a search with your zip code.
it will give you all kinds of info most important is contact for the node owner some owners like to keep their nodes secure others are like me and leave them open for any one to use or direct where ever they want. I have found most clubs that have a node connected to their repeater system like to leave it disconnected when not in use. my opinion is that's a waste, but opinions are like a holes every one has one and mine doesn't stink.
there are no requirements to announce you are going to shut down the node. again some locals like some kind of announcement my suggestion is disconnect than announce it why share your local requirements with the world . other wise enjoy your new hobby I have had a great time with it.
__________________
Don
1962 st-4
KL2ZF
  #46
Old 11-29-2014, 10:46 AM
squerly's Avatar
I'm confused Don, but that's to be expected at this early stage of the game. Don't you have a node # that I can connect to via EchoLink?
  #47
Old 11-29-2014, 10:48 PM
I have a node but it is an irlp node if you connect to echolink node kl7m it is bridged through the Alaska reflector allowing echo link and irlp to talk together. if you wanted a node to node connect I would have to coordinate it as I leave it connected to 9070 all the time Give me a call 907 304-1383 I can talk you through it and clear up the confusion.
__________________
Don
1962 st-4
KL2ZF
  #48
Old 11-30-2014, 09:04 PM
squerly's Avatar
It was trial and error for awhile but I found your node. Talked with a fellow (sorry, didn't write his call sign down) who said he hadn't heard from you today. Asked him to pass 73's to you and let you know I'll try again tomorrow.
I'm going to start building a directional 2 meter band antenna next week. Nothing too fancy but it should give me 7 db of gain and help me hit the (semi) local repeater. Also good experience as I charge into the never ending search for the perfect antenna.
I will also be setting up a OCF Dipole next week and hope to get a little more active with DX. I've had my Yaesu for over a month and never even had a chance to use it! But that all changes next week!
Have to hunt down Jev and KI0HO too!
The Following User Says Thank You to squerly For This Useful Post:
JEV (11-30-2014)
  #49
Old 11-30-2014, 09:15 PM
ki0ho's Avatar
ki0ho ki0ho is offline
Silver Member
ki0ho will become famous soon enough
Jev should not be to hard to find.......as for me ....I havent been active for years...all my gear is boxed up ....but one of these days I hope to get set back up again........
__________________
01-20-18 Lord grant me Patience!
Dembisels Happen
Many will follow their depraved conduct and will bring the way of truth into disrepute.
  #50
Old 11-30-2014, 09:18 PM
jim slagle's Avatar
jim slagle jim slagle is offline
Cold Member
jim slagle is on a distinguished road
Good luck!
I've looked for that for the last 38 years. I have come close a few times though.
Jim
__________________
The United States Constitution 1787. All Rights Reserved
Sometimes I'm fast. Most of the time I'm half fast!
Never put off till tomorrow what you can avoid all together!
Friends come and go, but enemies accumulate
FF REQUIRES NO PHYSICAL FITNESS PROGRAM.
EVERYONE GETS ENOUGH EXERCISE JUMPING TO CONCLUSIONS, FLYING
OFF THE HANDLE, RUNNING DOWN THE MODERATORS, KNIFING FRIENDS IN THE
BACK, DODGING RESPONSIBILITY AND PUSHING THEIR LUCK.
  #51
Old 11-30-2014, 10:03 PM
I think I herd a bit of that conversation it was Dave kl7m you were talking to with our recent snow I have been jumping in and out of the truck last couple of days. glad you discovered how it works .
__________________
Don
1962 st-4
KL2ZF
  #52
Old 11-30-2014, 10:09 PM
JEV's Avatar
JEV JEV is offline
Mr. Congeniality
Let's see...if I point the tri-bander with these bearings, I should "blow your doors off!" LOL You're a little close to me, but when you're setup we'll give it a shot. Maybe we'll start via long path for grins & giggles.
US State North Carolina
US County Macon
Bearing195.5 SSW (from KD8PFB)
Distance 470.3 mi ( 756.8 km)
Long Path24386.6 mi (39246.4 km)
__________________
Time to go fishin'
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
