I have decided to sell my Tucker, the reason is I haven't been able to use it as much as I had hoped. It is in great shape with no issues. I have owned it for 2 years and have done a fair amount of work to it in order to get it as reliable as possible. Here is a portion of what I have done.
2 new optima red top batteries
new plugs and wires
changed fluids in rear/front end transmission, transfer case,
two new hyfax on the front tracks
all new bearings and seals with synthetic grease 40 total
drilled and tapped wheels and installed new grease zirks
5 new wheels with several extras
several new u-joints
re-welded the fuel tank and installed baffles
new fuel pump
swapped the drive wheels so they wear on the other side
When I think some more I will add them
The Tucker has a fuel injected 318 with a five speed manual
winches on both ends that can be ran from the cab, heater works great has been recently rewired, has a ham radio, tracks are in good shape does not use a drop of oil or leak. Like I said it runs great my wife drives it more than me usually with our 2 boxers and lab. I have a new computer and will try to get some pictures on here this evening but if you want some I can text them to you.
Also I have a 14k tilt trailer that could go with it for there right price, all total I have about $19,500 in it so that is what I am asking without the trailer.
Any questions give me a call 406-570-3375 thanks
new plugs and wires
new fuel pump
