'68 Tucker 442 finds a new home
Pontoon Princess
Cattitute
Track Addict
Saw a truckload of Lubriplate headed up your way this weekend?
Rollers must be greased, diff/trans/transfer fluid changed, 50wt Racing Oil/Filter, Clutch fluid topped, greased fittings, greased pontoon journals, checked sprocket nuts, adjust hand brake, checked all bolts, checked spindle nuts, check tie rod nuts, table inspections, checked track tension, tuned stereo, Plugs/wires, washed/waxed, fueled ready for winter?
The Presidential range looked nice and snowy!
Track Addict
Wellness check. All is well.
Clutch slave needed adjustment as it was hanging in gear with pedal depressed.
Had to go through the build archives to figure it out remote. Marshall had it all resolved by the time I arrived in person!
Send more sno!
