Anyone knowledgable about concrete out there?
Adillo303
Diesel Truck Fan
I have brick front steps. There are three steps. The top an bottom steps are fine, The middle step disintegrated. All of the cement came apart. I took all the bricks out chopped the remains of the cement off them, Cleaned them up and reset them.
Being the sloppy individual that I sometimes am, I got mortar on some of the brickfaces. Is there any way to get it off? Wire brush?
DaveNay
Klaatu barada nikto
If it hasn't set up, you should be able to just use a heavy damp sponge (like grouting tile).
BigAl
Muratic Acid will help . Also a chisel and wire brush .
muleman
If it is already hard you need a wide brick chisel to clean most of it off. Then a wire wheel in a drill will get the rest off. They make a stone for cleaning up mortar also but they are expensive for a small job. I have one I use to clean block when I build walls. If you are in a cold climate most times it will freeze and come off next winter.
Adillo303
Diesel Truck Fan
Yes, I am in a cold climate. That may help.
It is hard already.
I will try the wire wheel and brush. It is very thin, I don't think I will need the chisel.
Thank you all for the advise.
