Not on the two Imps that I have, standard tracks, if you haven’t an axle puller you may want to buy a puller, if you are going to run you IMP much. What I do is hook a chain to the axle. Best if you connect it to the lug nut studs, at lease three of them that way you don’t damage the studs it takes a larger chain, an adaptor plate or a small piece of a large chain then connect your longer chain to that, also can hook around the back of the axle, if you do it this way put the lug nuts on the studs so that you don’t bang them up, BUT BE CAREFUL the chain can come loose and get you, someone or something else, kind of snap the chain pulling the axle out a little at a time, some come out very easy others kind of hard, but once again be very careful that the chain doesn’t come loose and hit you or something else, also be careful that the axle doesn’t come flying out and get damaged. Do not leave the sprocket on when doing this, as not to damage the sprocket. Good luck
