I will try to check on one of the parts machines I know of . yours is a 3 band model are they the same as the 2 band models, also check your chain the damage you are describing is from some one using an sae #08 chain. trust me I have been there and done that I sill have the residue to prove it
I think I could come up with snow trac sprockets but I don't know about the lower geared snow master sprockets
I need 2, ST42 front roller chain sprockets for my machine.
If anybody know where I can get them or have them made, I would be very helpful.
Mine are so bad that they are breaking teeth.
Any help at all would be appericated.
ST4B #2072
1977
Thanks for the info, I belive you are right. I just bought this machine.Maybe you should be finding why they are doing this?? Have you got SAE #80 roller chain? If so it is too narrow on the rollers for your sprockets, and can cause the condition you describe. What you need is Witworth "English" spec chain...
Are you running it too tight? or loose?? Normally we don't hear of troubles like you discribe if there are no other issues that cause this...
There was a recent thread about this topic of correct chain and sprockets. Will try and find you a link, http://www.forumsforums.com/3_9/showthread.php?p=602446#post602446 if this could be your issue.
Need help finding front exterior drive sprockets. Anyone know where to find in Alaska??? Two band ST4 type
I only know of one 3 band track model here yours is breaking teeth because you have an sae #80 chain on yours not the metric iso chain they came with. I dare you to ask me how I know? look at your chain and you will notice at the bottom quarter section of the sprocket the chain isn't seating properly and lifting up a little.one of our memebers had a machine shop in seattle lathe off the old teeth and weld on a new set of teeth. I cant remember the name of the shop but he used. the machine at mountain home lodge they have a web site you could drop him an e-mail.I need 2, ST42 front roller chain sprockets for my machine.
ST4B #2072
1977
