Since I installed a built-up 1995cc VW type 1 engine in my ST4, I lost the utility of the hand starting with the crank nut as it is now obscured behind the exhaust headers and the oil cooler. I figured why not see if I could make a crank fixture for the alternator nut.
Anyway I did and it was very simple to do, took less than 30 minutes total. It's just a piece of 3/4" steel pipe (1.05" O.D.) with some notches milled in it that's welded to the alternator pulley nut. It started cold after only about 3 or 4 attempts, and the angled notch in the nut ejected the crank without injury.
It's not like I can stand there and crank on it all day like a grist mill mind you, just through 1 maybe 2 compression strokes, but that's apparently all it needs to start. I suppose ff I was in a jam and it was very cold and I was low on motrin, I might cheat and use a squirt of ether. It's a great feature to have if you're out in the bush, and it's a good substitute for the hard-to-find crank nuts.
