I had to run to the pharmacy to pick up some medications for my daughter and noticed the local tractor dealer had the brand new Cub Cadet/Yanmars on display on his lot. As my daughter was not in urgent need of medications, I decided to stop off to inspect the new tractors. I was impressed with some of the features, underwhelmed with some others, and I have no idea what the specifications are for the tractors because, being Sunday, the dealership was closed. So I only got to sit in the seat and make pretend diesel sounds and only got to pretend to work the loader.
Still, I was able to get a feel for some of the features and make some judgements. I'm not sure that I like the BLACK over YELLOW paint, seems that the black might get very hot out in the sun? But it is a good look.
The tractor, which appears to be a 32hp unit, was sitting next to a Kubota L3400. The length overall of the Cub was noticably shorter, the height of the unit was also noticably higher. It appears the Cub has a higher center of gravity by several inches. The Cub has a curved arm loader design, as well as a curved & sloped hood similar to the New Holland tractors but the forward view of the bucket is completely obscured. I belive the overall height of the tractor blocks the view forward?
On the right side the loader control hoses are easy access, but also obstruct the ability to ingress/egress on that side. The left side has a step to assist in climbing up to the operators station. The loader control valve is fender mounted. The dash is easy to read with analog gauges.
