utahwilson
Hello,
SnowTrac Newb here. Just picked up a snow trac ST4 out of Las Vegas. Appears to be a ST4 with Track Master tracks. Anyway, the ST4 turns to the left perfectly, but has issues turning to the right. I have read Lyndons article on the variator adjustment top (easy) being done, but bottom (not being adjusted) can cause this issue. My question. What is the proceedure to set the adjustments to default and readjust both sides? Also, should I use steel wool to remove the glaze that has built up on the pulleys or just leave it?
I have posted a picture. Wife was not too happy that I ripped up the front yard.
Thanks
Thanks
