Electrical problems with the LMC1200
PJL
Started having electrical problems in the 1200. Some of the fuse holders were getting too hot and melting things. They weren't overloaded. The rivets had loosened over time and the connections were poor causing excessive resistance.
I wanted to update it with ATC style blade fuses and keep it in the the same location.
https://www.amazon.com/HELLA-H84960...t=&hvlocphy=9033308&hvtargid=pla-523116156236
I found a Hella 8 gang holder that would fit. The height was an issue but I figured I could use low profile fuses. Nope. Those only come in mini size and wouldn't fit. But the regular mini would. I put it all together and it worked great. Can even put the cover on. Now everything works again and the magic smoke has stopped leaking out of the wires.
JimVT
this is a picture of pete on the right with two other officers from our last outing together.
Cidertom
Chionophile
I'm going to chine in with my 2cents.
be cautious with using solder as the buss connection. That 30 amp circuit is able to get warm. It doesn't take much to get solder to a plastic state where it can creep. Then it becomes cyclic where the hotter it gets the less it conducts which causes more heat.....
CT
rockhead
CT
Good observation, to continue on that theme --- what would happen when 90 amps flowed on that left hand wire ?
PJL
The original fuse block had a soldered bus. It worked for 31 years. And that's not what failed.
PJL
Close ups of the factory wiring. I agree that solder isn't the best. I think a solid strip of copper with the connector screwed down would have been far better. I ran the cat yesterday for about 4 hours and all the circuits were fine. I touched all the connectors and none were warm. That's with all the lights on.
turbinator62
Site Supporter
That's the same type fuse holder I used in the imp. I used two 6 circuit holders and made the holes in the tabs bigger and soldered the bus wire through the holes. It has worked fine for 6 years now. I used two 6 circuit fuse holders but the one on the right is split 3x3. 6 circuits on accessories, 3 on ignition and 3 on battery. I have a lot of electrical stuff to run.
redsqwrl
to cider toms point.....
I had a bad experience in a 2100 this winter. I believe the factory engineers may have used silver solder or something more substantial that 60/40 malleable solder.
Tight clean connections will never draw heat.
a mouse nest can stress out a fan motor causing the motor run beyond slip which makes for a slow build of current, (pronounced heat) the temp rise is minimal, you won't feel it as it is very local to the failure. as the nonferrous material work hardens from the cycles of heating it becomes what you experienced. ( a localized hot spot)
I was out with a electrically distressed machine that had some expert repair to the wiring by a previous owner. ( that was sarcasm)
Those poorly executed CRIMP and SOLDER connections became compromised due to a Ice scrapper that had slipped down into the heater box dragging the fan down and causing some distress on the circuit, by the time I figured out what was going on, I was without heat........ ( that ice scrapper fell in there long ago )
a emergency field repair suitable for a reality show was in order, I made a call into the compound to let my wife know I was somewhat in a uncomfortable situation got some help moving in my direction.
thiokol 2100 heaters are not much to start with, but having some repair stuff along, combined with the ability to deploy them provided me the ability to only have a little frost bite on the back of my right calf and the tops of both hands.
For what ever this comment is worth, the national electrical code prohibits circuits that rely on solder only. they must be mechanically made first then soldered.
Turbinators connections are an example of this. the pig tail and t tap are wire twisting procedures that are made to be soldered.
turbinator62
Site Supporter
I used to hold a Solder Certification card for Nuclear, weapons, and aircraft when I worked for the Navy. 2 week school. They were real picky about that stuff. Especially the nuclear inspectors. Turret posts had to be between 1 1/2 and 1 3/4 turns with a 1/8" tail. No more, no less.
Unless you really want to change it, it will probably be ok. Make sure there is plenty of solder on the tabs and the wire is well wetted and flowed into the stranding.
I've actually had more problems with bad crimps than soldering.
