Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > ATA (Alaska Track Association) Forum
ATA (Alaska Track Association) Forum Forum to Keep members up to date on ATA plans, meetings and outings.
Reply
Thread Tools Display Modes
  #1
Old 07-13-2015, 12:56 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Default Snowtrac sprockets
So as the ATA is a new member here maybe you could help locate the mold from the foundry that closed in North Pole Alaska? Or do you have it already?
There are a number of members looking for new sprockets in the not to distant
Future.
Also be sure to ask member Bob about circus tents I'm sure he will smile.
__________________
The Tracks you leave today, Will lead you to the future!
  #2
Old 07-14-2015, 12:23 PM
Sno-Surfer's Avatar
Sno-Surfer Sno-Surfer is online now
Sno-Surfer is on a distinguished road
Default Re: Snowtrac sprockets
Count me in as one that's looking for two band sprockets. My current ones are made from steel it appears and wearing through the grousers.
Anyone one has a line on a set please let me know. Thanks.
  #3
Old 07-20-2015, 04:50 PM
Snowcat Operations's Avatar
Snowcat Operations Snowcat Operations is offline
Gold Member
Snowcat Operations is on a distinguished road
We have several members who also need sprockets. We also have one member who is making them out of a specialized plastic. We are also tracking down molds as well. I will pass on the info at this Wednesday Club meeting in Palmer AK. If anyone wants to drop in feel free to do so. Contact us here.
__________________
EVIL prevails when good men stand aside.
  #4
Old 07-23-2015, 03:11 PM
Gold Member
Talking Re: Snowtrac sprockets
Future.
I DONT HAVE ANY IDEA OF WHAT YOUR TALKING ABOUT BOGGIE?...... this is Bobcat smiling by the way.
__________________
  #5
Old 07-23-2015, 03:18 PM
Snowtrac Nome's Avatar
guess who got that pic of the infamous bobcat, next to a cat that doesn't look like a bath tub
__________________
Don
1962 st-4
KL2ZF
The Following User Says Thank You to Snowtrac Nome For This Useful Post:
Snowcat Operations (07-23-2015)
  #6
Old 07-23-2015, 06:48 PM
Gold Member
I must say that I will not divulge my resource for that picture. I sir will go to the grave with that information. I wont mention that he lives in Nome, Alaska. I will also not divulge that he has a real snow cat (Snow Trac) either. His trust of me with such vital information and blackmailable information has humbled me. Thank you Snow Trac Nome for the picture.
__________________
  #7
Old 07-23-2015, 06:51 PM
Gold Member
I must say. Bobcats lack of response is proof positive the he knows deep down inside that his Kristi truly is a Krusty.
__________________
  #8
Old 03-28-2017, 11:55 PM
SnowTrac Hunter's Avatar
SnowTrac Hunter SnowTrac Hunter is offline
SnowTrac Hunter is on a distinguished road
300 H&H had posted dimensions previously for sprockets. Niels sent me an STP file which I could open with Wedge, but without having a compatible version of AutoCAD I couldn't dimension.
The dimensions that were posted in another thread were slightly incorrect, so I am trying to correct per layout. I am going to try and make a weekend trip to verify. Three hour drive and couple mile hike in to cabin. The dimensions below are what I have come up with so far. Please feel free to correct me if I am off base.
Outer Tooth Diameter - 17-1/4" (17.25")
Outer Tooth Radius - 8-5/8" (8.625")
Base Diameter - 15-3/8" (15.375")
Base Radius - 7-11/16" (7.6875")
Tooth Degrees - 90*, 77.1428571*, 51.4285714*, 25.7142857
Circle Circumference - 54.19247"
Tooth Center to Tooth Center - 3-7/8" minus (3.8708")(14 Teeth)
Tooth Tip Width - 1" (Need to Verify)
Space at Base - 1-1/2" (Need to Verify, May need to be 2" for grouser which would take out slope)
Thickness - 1/2" to 1" UHMW depending on model.
Hope this is helpful. I have an older two band model. I would like to start out with 1/2" and see if it is durable enough before I modify my sprocket to fit thicker UHMW. Prices of UHMW vary depending on location. I purchased a piece of 18" x 10' for $350 in Anchorage, Alaska. You may be able to find cheaper in the Lower 48.
Thanks,
Joe
__________________
Joe Billy
1964 ST4 #446
The Following User Says Thank You to SnowTrac Hunter For This Useful Post:
NE-Iowa (03-29-2017)
  #9
Old 03-29-2017, 12:37 AM
300 H and H's Avatar
Keep us posted on your progress. My self and others are exploring UHMW cut on a water jet currently, as well as some Silicon Bronze foundry efforts. Snow Trac No. 268 has been running some UHMW with careful inspections, and some rotation of the sprockets for several years now. I like the quiet operation the offer, if they can be made to last well enough.
__________________
Snow trac ST4 #267
The Following 2 Users Say Thank You to 300 H and H For This Useful Post:
NE-Iowa (03-29-2017), SnowTrac Hunter (03-30-2017)
  #10
Old 03-30-2017, 01:20 AM
Will do. I need additional measurements from my track rig such as Center hole dimension, mounting bolt spacing and size, and actual grouser bar size to complete. I am hoping to make a template and cut 6 to 7 out of the piece of UHMW we bought. I was going to buy some premade from the local plastics shop, but the cost was prohibitive.
__________________
Joe Billy
1964 ST4 #446
bill w (01-12-2018)
  #11
Old 03-30-2017, 01:31 AM
I am tired of backing up steep hills. There may be some additional maintenance needed after I replace the sprockets. Will have to see. I would like to have it running good at least for one winter. Engine has run great since we rearranged the plug wires and went to an electronic ignition.
The pics of the layout do not show the center hole size or the seven mounting hole locations. Needs work. I will repost the pics with all the dimensions when finished.
__________________
Joe Billy
1964 ST4 #446
  #12
Old 03-30-2017, 10:37 AM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
just to chime in, I work slow but never stop.... We have a scanner here that might be able to grab those points as well.
I am relying on others for help with the tooling but we will get there.
thanks for taking a lead.
  #13
Old 03-30-2017, 01:25 PM
I would think you have something else going on. I run my sprockets till the start breaking teeth usually some where between 1/4 and 5/16 of an inch, never had one slip ,if you have forward movement slippage I would look hard at chains and sprockets. mine got severely worn last winter from a rental I threw a new sprocket on and shortly after word threw a chain, after replacing chains I saw where the old chains hadn't been seating in the sprocket from the bad link bushings changing the pitch
__________________
Don
1962 st-4
KL2ZF
  #14
Old 04-04-2017, 01:13 AM
Quote:
Don,
Quick look at inner drive sprockets and chain did not reveal any wear. Will take a pic of the bronze sprocket that I removed and post. Looks like they had tried to cover with a Black plastic that has worn off. It was worn down to nubs. I will check to see if I can adjust tension to help. Not sure of what it should be.
__________________
Joe Billy
1964 ST4 #446
  #15
Old 04-04-2017, 01:22 AM
Close-Up of bronze tooth with Black Plastic covering
__________________
Joe Billy
1964 ST4 #446
  #16
Old 04-04-2017, 01:29 AM
Trying again.
__________________
Joe Billy
1964 ST4 #446
  #17
Old 04-04-2017, 08:33 PM
those are well worn I replaced a set that looked like that this winter
__________________
Don
1962 st-4
KL2ZF
  #18
Old 01-12-2018, 01:25 AM
Tooth Center to Tooth Center - 3-7/8" minus (3.8708")(14 Teeth/Lug)
Tooth Tip Width - 3/4"
Space at Base - 2"
Mounting Hole Radius - 5-7/8"
Mounting Hole Size - 1/2"
Inner Hole Diameter - 10-1/4"
Inner Hole Radius - 5-1/8"
Sorry it took forever to post finished dimensions. Snow Trac was low on my priority list this year.
Took about 3/4 day to router out seven sprockets when I finally got around to it.
__________________
Joe Billy
1964 ST4 #446
jim slagle  (01-12-2018)
  #19
Old 02-08-2018, 04:11 PM
akmountaineer's Avatar
akmountaineer akmountaineer is offline
akmountaineer is on a distinguished road
I have a couple of used ST4B sprockets that are in pretty good shape. Can anyone suggest a reasonable price for what I should list them for in the classifieds?
__________________
  #20
Old 03-29-2018, 11:51 AM
JimVT's Avatar
JimVT JimVT is offline
to bad you can't rebuild them
i didn't realize i had so many.
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Sprockets for ST4 jakers Snowcat Repairs, Parts & Problems Forum 18 11-20-2014 01:20 PM
Sprockets! meanjean Snowcat Classifieds (For Sale / Wanted) Forum 12 12-02-2013 02:40 PM
snowtrac sprockets brianf Snowcat Restoration & Modification Projects Forum 7 09-14-2012 01:03 PM
My New Sprockets trackmaster Snowcat Adventure & Usage Forum 0 03-18-2012 11:56 AM
need value of 601 sprockets mkntrakes Snowcat Repairs, Parts & Problems Forum 2 01-30-2010 02:59 AM
