paulhenry
Bombardier skidozer 1986 252G
Having trouble locating parts - NEED INPUT ASAP.
THANKS FOR YOUR PROMT RESPONSE.
Need ASAP parts and part numbers for this unit. Damage to bearings destroyed part numbers and they are standard Timkin bearings I think which are available locally if I had part number.
Also need axle and housing, driver side.
Parts list reads as follows:
Driver side
axle hub gasket
oil seal
ol seal support
lock washer
cone bearing
lock washer bearing cap lock nut
internal seal support
axle shaft
axle shaft housing
Driver side
axle hub gasket
oil seal
ol seal support
lock washer
cone bearing
axle shaft
axle shaft housing
