WTS: 1980 Skidozer SV252 $16k
dzuppio
Refurbished 1980 Skidozer SV252. sand-blasted & primed & painted, all tires foam filled, new foot brake, new brake lines, new coolant hoses, alternator, water pump, reconditioned radiator, LED 50" light bar front & rear, LED strobes, stereo, roof paneled, new fuel tank, 1 single-line hydraulic pump, 1 dual-line hydraulic pump, dual batteries, 1 new sprocket, Ford Indus. 300ci engine, automatic trans, unknown hours (meter not working when i bought it)
$16k or BRO
8 x 18 AFMI refurbished drag. $5k alone, $4k with the Skidozer. BRO
dzuppio
more pics
dzuppio
even more pics
dzuppio
more even more pics
MNoutdoors RIP
dzuppio
What is the type of your tires (industry and size number)
Nikos
They were produced by Goodyear, 5.30x12 6 ply smooth, many will fill them with polyurethane to flatproof.
Some machines have the solid rubber tires but they require a two piece wheel
They are very durable,but ride rougher,and cost over 500.00 ea tire only
Aaron Tucker
this is a good looking cat with 4 doors for the price . not really a deep pow cat tho with those tracks . would be perfect for the east coast
Ginodellapenna
I have a couple of questions I hope someone can help me with. This would be my first cat so I don't know much about them other than my own internet research. I would use it on the colorado front range on mountainous terrain.
Would this cat be good in Colorado powder?
How well do they climb?
I appreciate any input. Thanks
Nikson
Best way to find out - is to buy it...
Price is great considering its shape, and he is half way closer to ya...
If he was anywhere PNW area - I would consider for sure...
undy
It appears to have the same (28"?) tracks as mine. I would think that it would not do particularly well in deep Colorado powder. Mine's ok here in Wis., but that's much different snow.
GlacierSean
I live and snowcat in the Colorado front range mtns but I am not familiar with how well a skidozer will do. The two important factors when it comes to snowcat performance are ground pressure and power to weight ratio. The skidozer your looking at has a ground pressure of 1.0+psi, not great but not terrible. And that's before you load it up with people and gear. My cat has a ground pressure at around 0.6psi stock and is probably around 0.75psi with the modifications, most Tucker's are 0.95psi.
Most of the snowcating I have done in Colorado is at 10000 to 12500 feet in elevation. At that elevation you loose at least 30% HP, so power is very important. I recommend something with EFI and a lot of power. Unfortunately most "vintage" snowcats don't come with a lot of power stock. If you buy something that has hydrostatic drive torque is what you want to look at instead of HP. Hope this helps and see you on the hill.
