Chrysler Slant 6 HB-225 distributor vacuum question
Track Addict
My 73 tucker has an industrial slant six. Motor runs excellent at all rpm. Has a ball and ball carb.
Noticed today the vacuum hose off the distributor was just looped and goes nowhere. Hose end looks broke off but I can't find the vacuum port?
Where would it be ?
Track Addict
Little more info. The carburetor is a mid 60's Carter BBS C-1 3276 S. I believe the port is on the motor side of the carb which right now is and empty hole. Will take a closer look.
Track Addict
Figured it out. This is the spot where the nipple should be for distributor.
Also explains the studder from idle to open throttle . Going to have rebuilt and the missing part installed.
Thanks for listening!
you are looking for a port with venturie vacuum .iit will only supply vacuum when the throttle plate is opened.
