Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Oil, Lubricants, Engines & Misc Forum
Reply
Thread Tools Display Modes
  #1
Old 04-11-2011, 04:44 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Question #2 Diesel -vs- ULSD (Ultra Low Sulfur Diesel)
My car and my tractor both run on USLD.
I have the opportunity to buy 250 gallons of #2 diesel.
This may be a really dumb question, but what is the difference between #2 diesel and the typical road diesel that is sold at truck stops/gas stations for use in on-road vehicles?
Can #2 also be USLD?
__________________
- Ayn Rand
  #2
Old 04-11-2011, 05:13 PM
DaveNay's Avatar
DaveNay DaveNay is offline
Klaatu barada nikto
DaveNay is on a distinguished road
Default Re: #2 Diesel -vs- ULSD (Ultra Low Sulfur Diesel)
Quote:
FD&C Red #2?
__________________
Never ascribe to malice, that which can be explained by incompetence.
Napoleon Bonaparte
If God were suddenly condemned to live the life which He has inflicted upon men, He would kill Himself.
Alexandre Dumas
  #3
Old 04-11-2011, 05:25 PM
snow dog's Avatar
snow dog snow dog is offline
Silver Member
snow dog will become famous soon enough
if you get caught with red diesel in a motor vehicle on a highway, it can be expensive. stay off road is best.
  #4
Old 04-11-2011, 06:16 PM
Melensdad's Avatar
I have no clue (yet) if the fuel is dyed red. And I know that is a real problem. So let us set that aside.
For the sake of my question, I am still asking is there a difference between #2 and road fuel or is #2 the basic ULSD that is commonly sold at most truck stops?
__________________
- Ayn Rand
  #5
Old 04-11-2011, 06:26 PM
Snowtrac Nome's Avatar
for you guys all your diesel since about 06 intended for use in piston engines has been ulsd either #1 or #2 so a good guess is it's already ulsd yes if it's dyed it is tax exempt which it's only good i off road equipment also if it has set for a while treat it with a bioside to kill any algee in it lastly as long as none of yourequipment has a dpf than you can run older low sulpher diesel or jet fuel in it with no adverse affects. again jet fuel has no road tax so you can't run it on the road unless it was origionaly sold as #1 low sulpher diesel and taxed as such
__________________
Don
1962 st-4
KL2ZF
  #6
Old 04-11-2011, 06:38 PM
snow dog's Avatar
Silver Member
I thought Engines made before 2006 were designed to run on High sulfer diesel and when Ultra low sulfer came in 2006, and used in pre 06 engines, it would work but over time causes problems with the injector pumps.
  #7
Old 04-11-2011, 06:48 PM
there is some accelerated wear with ulsd in pre 06 engines but all ulsd have additives added to improve lubrication so you can safely run it in pre 06 engines wear is about the same as you will run into if running #1 or jet fuel the big problem comes as there will be a change to ulsd heating oil no additives don't run that stuff in your engines
__________________
Don
1962 st-4
KL2ZF
  #8
Old 04-11-2011, 07:59 PM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is offline
Gold Member
EastTexFrank will become famous soon enough
Quote:
That's good to know. I've heard from so many people on tractor boards that use home heating oil in their farm equipment.
I wonder how long it will be before someone offers an additive package for home heating oil so it CAN be used safely in farm equipment?
__________________
ETF
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them. John Wayne as JB Books in "The Shootist".
  #9
Old 04-11-2011, 08:52 PM
the best additive you can get is 2 cycle motor oil and mix it to about 10%
don't exceed that or your viscocity will be too thick
__________________
Don
1962 st-4
KL2ZF
  #10
Old 04-11-2011, 09:31 PM
BigAl's Avatar
BigAl BigAl is offline
Platinum Member
BigAl will become famous soon enough
Would'nt it be easier to just add a diesel additive to the oil ? Problem solved .
PS .
Bob ,
I would do it in a heart beat !
__________________
Big Al
2B1ASK1
See my Kristi Video here : Kristi KT3 - YouTube
Disclaimer: Read with caution !!
Poster may be Bad Speller at times .
  #11
Old 04-12-2011, 11:49 AM
there are sevreral comercial additives to improve lubrication out there the big names like amzoil and power service scored pretty low on the test some of the europeon made additives which must be injected into the product while it's pumped out of the bulk plant scored much higher the real wild card came with redneck fixes atf sucked motor oil did to the theroy being it was not desighned to be suspended in fluid but 2 cycle oil scored in th high 5's of the test results i saw
__________________
Don
1962 st-4
KL2ZF
  #12
Old 04-13-2011, 06:59 PM
300 H and H's Avatar
300 H and H 300 H and H is offline
300 H and H will become famous soon enough
Bob,
Go to Wall Mart or other source and get two stroke eingine oil, TC3 ashless. Mix a quart to 30 galons of diesel and forget your worries. I do this in my 06 pickup truck with every tank full. About 128 to one ratio, and will replace any lack of lubricant.
Kirk
__________________
Snow trac ST4 #267
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Diesel and 18 wheels johnday Heavy Equipment Forum 28 10-12-2009 06:32 AM
What's Up With Diesel? BoneheadNW Misc Consumers Forum 59 04-16-2008 08:54 AM
New Diesel Motorcycle humor_me Motorcycles & Accessories Forum 0 07-04-2007 09:16 PM
Diesel or gas engine ??? BigAl Snowcat Repairs, Parts & Problems Forum 17 11-17-2006 08:47 PM
Diesel Oil johnday Oil, Lubricants, Engines & Misc Forum 5 04-08-2006 07:15 PM
