Bombi carb
tango
Hi guys, I recently bought a bombi and working on getting it fixed up. I had to replace the throttle cable. With out throttle cable installed With the machine not running and you manually open throttle wide open the butterfly inside the carburetor only opens about 15-20% is that normal on these. Most carbs I have been around the butterfly opens all the way from horizons to vertical. This also has the handy governed mounted below carb on top of manifold. Just want to figure this out before moving on thanks.
MNoutdoors RIP
That’s not normal it should open more than that
Bobcatbob
I recently had the carb off my Bombi replacing the diaphram. The butterfly should open to at least a 45 degree angle. Check the alignment between the hoof govenor and the carburetor.....the barrels need to line up for the butterfly to open (loosen the two mating nuts and see if you have it lined up).
Bob
tango
Thanks for the info. I will check that. It sure acts like something is not right. If I manually open the throttle the diaphragm pump arm just starts to push the diaphragm and stops. I can physically push the pump diaphragm with my finger another quarter inch or so. When I start to go up the smallest hill I power out but I find I pump the gas pedal a lot the power comes back.
Bobcatbob
That’s exactly the problem I had. I replaced the fuel filter, then the diaphram (an Autolite 1250 carb rebuild kit will have the correct diaphram). Fuel filter had crap in it....and the diaphram was like vulcanized rubber. Once I did those two things, ran like a champ (now I’m doing a full restoration on the machine....rust was winning).
If those don’t work (after making sure butterfly clears hoof governor opening), check your fuel pump, then fuel spray in carburetor.
Bob
tango
When I do open the throttle as far as it will go it does move the diaphragm plunger just slightly and it sprays gas but not a lot. The machine is up at the cabin 100 miles away so won’t get a chance to work on it for a week or so.
tango
I know it’s hard to see top pict has butterfly closed second pict is wide open throttle but you can see the butterfly hardly moved.
Bobcatbob
Yep.....looks blocked (or linkage has play in it). Let us know how it turned out.
If the carb hasn’t been rebuilt in years, consider a new diaphram (my old one had pin holes and was leaking)....possibly gaskets as well. I couldn’t find a manual on this particular carb (they were made by ford for the Kent engine), otherwise I would have rebuilt it.
Bob
snowcatt
When the carb is on the table does the butter fly open .?
As for the governor I remove them and make a block or remove the butterfly and make sure it’s sealed around the gasket on the side plate they like sucking air
I install a tachometer and red line 5 grand on all the ones I restored
Have fun
tango
Thanks for all the good info. I haven’t had a chance to pull carb yet to see if butterfly is hitting like bobcatbob had mentioned. Is it much of a job to take off the governer not really sure how’s those work. I wish I had it here in my shop instead at the cabin. I can’t wait to start tinkering on this unit.
tango
Ok guys, I hauled bombi home and here is what I’m finding. I loosened the carb up moved it around a little bit working the throttle linkage by hand trying to get it to open up like bobcatbob suggested but had no luck. I than pulled the carburetor off and found the hole in the governer is square and smaller than the butterfly. That is why you can’t open up the butterfly. With carburetor mounted at full throttle butterfly is open less than 10%. With carburetor off and open the throttle with linkage butterfly opens to 90 degrees of carb. The butterfly is slightly bent from hitting govenerrbase from operator pushing on pedal trying to get it to open up. Is that the way there made? I have never seen anything like this before. I lifted the governer up slightly off manifold and manifold has round hole same as carburetor. I will post a few pictures. I sure could use some input on this thanks all. First picture carb off butterfly all the way open. Second picture is if carb was mounted this is all the further butterfly will open. Third picture is square hole on top of govener. Thanks. CAAA692E-B7F5-482A-8523-4638D1016F8E.jpg
snowcatt
Get a block made is what I would do. Make it out of aluminum if you find a 1”
Piece you can make it yourself. Hole saw use WD40 to keep the teeth clean
The machine will run way better .the thing that someone put in there is wrong
They had a round hole in all the ones I took out
Have fun
I was out yesterday lots of snow in the bush
tango
Think I will take governer off and open up the square hole to match carburetor. I have a big mill and boring bars to do this. Just didn’t want to screw governer up if this was in fact the way it was designed to work. I didn’t want to bore it out then find out that it was correct and have to look for new governer. Thanks
PJL
If you do totally disable it which seems like the best thing to do you can add an electronic rev limiter to prevent overspeeding the engine.
snowcatt
What I’ve been doing is taking out the hour meter and putting in a digital 2”
Tachometer in the hole with a 5 grand red line
Good luck have fun
tango
Good catch on the notch on bottom of carb sucking air. I will put on new gaskets of course and check those notches and see if those are cut all the way through. There is already a tach mounted in it but I will replace with a new one. With governer on as normal the most RPMs I could get was 2200. That is why I started digging into this thing The gentleman I bought this from had it 5 years but never used it. Surely at some point this thing had to open up more than this but I don’t see how with that square hole governer I’m sure this bombi project will turn into a all summer project. Thanks for all the good advice
tango
I have machined out a new piece of aluminum to put where that governer was. It fits perfect. Straightened the throttle butterfly put it all back together and it literally doubled or more the horse power and response time of machine. Snow is about gone so I parked in shop and going to do a complete tear done to inspect and see what else I can find and give it a paint job. I’m looking for new louvers for engine cover are they available any where? Thanks
snowcatt
There hard to find in good shape which ones do you need .ill check and see what I have
I’ve made them out of metal it’s not that hard
MNoutdoors RIP
The original plastic ones. Are no longer being made, but several options are
Aluminum or steel louvers. Do a search on eBay you can but sheets of them and cut to suit. Or some make them from expanded and flattened metal. If your a welder you can build a box from angle iron and then weld flat bar at a angle to create the louver
snowcatt
I made louvers out of metal very simple like MN outdoors said
I checked my stock they all have corners missing nothing worth using
Good luck and have fun
ezroller
Have fun
Pro tip right there
