KOMATSU D66S IGN. WIRING NEEDED
GREY249
D66S IGNITION KEY WIRING COLOR TO CORRESPONDING TERMINAL (ACC., C, B, ETC) WRITTEN ON BACK OF IGN. SWITCH. BOUGHT MACHINE WITHOUT IGNITION SWITCH. THANKS
Dmorency
Try this. Terminal B two large red wires
Terminal BR red/black wire
Terminal R1 Brown wires
Terminal C white wires 3 together
Terminal ACC Grey/ red wire
Terminal R2 not used
GREY249
THANKS for the much needed info, but when I look at the existing wires that come to the switch, I have all single wires, YELLOW , BLUE , WHITE , BLACK , GREEN and a RED/ WHITE wire that is taped off. No other or double wires. Any thoughts of properly wiring in the ignition switch? THANKS AGAIN, Keith
if you still need the help I have a d65 manual I would bet they are the same
