Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Trailers & Tow Vehicles Forum
Reply
Thread Tools Display Modes
  #1
Old 10-28-2006, 08:00 PM
mungo45 mungo45 is offline
Junior Member
mungo45 is on a distinguished road
Default Homemade Trailers
Hi, I am looking to buy a homemade trailer from an independent seller. He does not know what the trailers GVW is. How to you determine what the GVW is of a perticular trailer. It is a dual axel 8x16 deckover.
any help is appreciated
  #2
Old 10-28-2006, 08:33 PM
bczoom bczoom is offline
Super Moderator
bczoom will become famous soon enoughbczoom will become famous soon enough
Style: T66
Default Re: Homemade Trailers
Are you going to register it for road use?
If so, check with your DMV. They normally require a couple inspections to determine the GVWR as well as road-worthiness.
At 16', you're right on the cusp of what needs to be inspected. In PA (where I am), any homemade trailer over 16' needs inspection by either the Sheriff's department or State Police.
I don't know where you are but in PA
__________________
If you didn't hear it with your own ears or see it with your own eyes, don't invent it with your small mind and share it with your big mouth.
  #3
Old 10-28-2006, 08:40 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Even with a homemade trailer the trailer needs to be registered, to obtain a registration it would need to have a declared GVW. There is no way to license a homemade trailer (that I know of) without it being registered.
The GVW of the trailer will depend on the axles, 2 3500# axles would be a 7000# GVW, 2 5000# axles yield a 10,000# GVW. Subtract the weight of the trailer to determine the load capacity. A 16' trailer will likely weigh 1500# to 1800#. Tires also determin the weight capacity, check those! One fairly common trick is to use cheap tires, so you may think you have a 10,000# GVW trailer but only have tires that can hold 7000#. Each tire will have a capacity molded near the bead.
__________________
- Ayn Rand
  #4
Old 10-28-2006, 08:45 PM
Super Moderator
Style: T66
Quote:
Originally Posted by B_Skurka
The GVW of the trailer will depend on the axles...
Also, the frame and coupler size will be checked to determine capacity.
If it has a 2" coupler, they probably won't give you more than 5000#. A 2 5/16" will be required for the 7-10K# rating.
I don't the specs on the frame but I'm thinking the main beams on a 7K# trailer are 6" and they're 8" for a 10K# trailer.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Snowcats on Trailers ~ Safety Questions? Melensdad Snowcat Adventure & Usage Forum 6 10-23-2006 10:01 AM
Are these trailers worth anything? bczoom Trailers & Tow Vehicles Forum 5 07-31-2006 03:58 PM
New homemade clamp on pallet forks. PBinWA Tractor Forum 26 04-24-2006 09:46 AM
New Homemade toothbar and brush mover JimR Tractor Forum 6 04-12-2006 08:32 PM
Snow Vehicle trailers J_Josue Snowcat Repairs, Parts & Problems Forum 9 02-27-2006 11:05 AM
