So Im looking under my hood today just to see if I have the original COPs. Well I look on the drivers side up against the fire wall and I see a bunch of wire and it looks like the protective back plastic covers are off. Then I look closer and there is a damn wire cut!!!
So I get a razor blade and splice and put the two ends together. I turn the car on and WAMM-O! Engine light!!!
I take my 03 p71 to Auto Zone to have the code read.
It reads P0430
NOW what do I do????? Do you folks think its just the sensor?
It reads P0430
Catalyst System Efficiency Below Threshold (Bank 2)
What does that mean?
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 (passenger side) is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
