1201B Carb
barnstormer
So I'm finally getting back into my Spryte after a couple of years of neglect. She wanted to run. I could make her pop and rumble with with a little starter fluid down the carb but no real run. I pulled the carb off and opened it up. This is what I found inside.
I guess I need a new carb. Its a Webber single barrel. Any one know where I can get one?
barnstormer
I guess I don't know how to post a photo.
The float bowl is completely corroded filled with white goop. I tried some cleaner but I don't think it can be saved...
muleman
To post the pic copy and paste it to your desktop with a name like old carb. Then click on the paper clip next to the smilie above the post window. It will open a new window and you click browse and select your desktop and click on the name and then click upload. As long as you have some text in the window it will attach it to the post.
I have a small ultra sonic parts cleaner ,I filled it with ulsd ,and have had good luck at cleaning out carbs and rebuilding them. even with old atv carbs that look like what you describe
