Anyone out here have one?
I got the opportunity to get some seat time in 2 of them last weekend. One with FEL only, the other had the backhoe as well. Both have approx. 30 hours and are HST.
Although I only got about 3-4 hours time, I did notice some things that I found perplexing and was wondering if you could provide any insight, particularly if it's a potential problem or issue with the particular unit so I can let the owners know that a repair may be in order.
- It was almost impossible to get into or out of 4wd (I had to lift the front tires off the ground with the loader, play with the HST pedal and stand on the lever to engage 4wd).
- On one of them, when in neutral but range selector in L range, it crept forward.
- On the backhoe, without command, the boom was sliding to the right.
- Backhoe controls seemed very jerky. It was very difficult to make any finess movement.
- Difficult to back up the a slight incline in M range.
- The backhoe seemed weak. Most anything other than soft dirt would stop it.
- Throttle lever was very difficult to move/adjust.
Other things that made me scratch my head.
- The ROPS is over 8' high.
- With the ROPS that high, the canopy didn't offer as much driver protection and also restricted travel in wooded areas due to total height.
- COG "appeared" too high for that size tractor but I wasn't on any ground that could/would generate a pucker.
- "Seemed" to go through A LOT of fuel for a 25HP. I was normally in the 17-1900 RPM range.
My dad is one of the owners (the one without the hoe). Although this tractor is relatively new to him, he did say that if he was to get another, it would be the C30 and would have to have a lower ROPS.
