Converting to a 5 man cab!
KickerM
Site Supporter
Howdy all,
Started this project of converting my SV-250 from a 2 man cab to a 5 Man Cab, I want to make it as close to factor as possible so who out there can tell me the measurements...
Total Length of cab and Width of the rear door?
THANK YOU in advance!!!
KickerM
Site Supporter
Anybody out there? If you are measuring it, I also was wondering what the window dimensions are?
Thanks again!
And no the SV-252 in the picture is not mine, or I would just go measure it!:yum:
when I did my 252 I put a rear cab all the way back and opened the back of the cab up---flt. beds do nothing but collect snow--- we would pack a bunch of people in it and go bar hopping----ill have to fire up my other computer and post a pic. of it
KickerM
Site Supporter
I have considered that also, but occasionally need to haul feed out to the cattle if the snow gets too deep, so how heavy a rack would I need to build on the top?
Pontoon Princess
Cattitute
just a silly tucker sno-cat owner chiming in, why not build a wonderful roomy cab, and then build a tow behind, over the snow, trailer for your other purposes and needs...
KickerM
Site Supporter
Lots of good ideas here! I would love the idea of a Full Man Cab, just not practical for me. I'm going to put a dump bed on the back so its easy to unload, weather it be firewood, hay, or a bunch of Rowdy Snowboarders:th_lmao:
Heres a pic now that I got the back of the cab off! Along with a mock up of the Door Jamb and Roof Edge Pieces I need to make... Off to the Fab Shop!
dep6113
make sure you keep an eye on how your going to route the exhaust and get the hot air out from the radiator out under the cab---it will build heat pretty fast . i started with two basic electric fans and had to upgrade to high flow units which needed a 105 amp alternator instead of a 60 amp alternator.
KickerM
Site Supporter
Good Ideas! So did you remove your mechanical fan to save on power?:brows: Could a person mount the fans on the engine side of the radiator blowing out(forward) instead of blowing through the radiator then over the engine? Or would pulling the warm air from around the engine and through the raidiator be too warm to do any good? Because I’m pulling the engine and having it all gone through as long as I’m this far into it! Thanks!
KickerM
Site Supporter
Well Now I done it! It appers that the oil pan had a little bit of oil on it...so that requires a new gasket which you guessed it, I must take out the motor to replace so...well I'm this far into it I might as well go through the whole engine and transmission at this point!
Does anybody know the part number or cross reference for the radiator out there? It has been mentioned (Thanks dep6113!) that I need to maximize cooling and nothing cools better than a new radiator!
build your new cab all the way back----a box or flt. bed on the back does nothing but collect snow---or fall off----this was yesterday out doing trail work----and you can be sure that the next day its not below zero my tractor will be taking it the rest of the way off and to the burn pile
this was my sv252 I redid------I opened the cab up between cab and box---I also made it so I could pull box and reinstall back of the cab if I ever wanted to run with out the rear cabin----and yes air flow is key---I also ran the tail pipe next to drive shaft and out the back---I run heated pans on my drags-------second pic. having a few on a nice winter day---my cabin had top hatch and built in rops.
KickerM
Site Supporter
Looks awesome! How did you do your fuel tank and your hydraulic reservoir?, I like the outside tool boxes on the sides! Thanks
they are still in the same spot behind cab on each side---I put a filler panel in between cab and box----if u look there is an opening to help let hot air out on each side-----on the inside of the box/cab---the tool boxes were the bench seats down each side----It was so much fun putting a crew in that thing and go party in it---it was neat having frt. cab opened up to the rear cab----when we would pull into a bar with it loaded with people it was way cooler than a limo---hell----we could even switch drivers with out stopping
dep6113
I removed the mechanical because the bearings were bad in the idler and i didn't want to mess with it. i replaced my radiator with an aluminum radiator i got off of ebay-- I looked but i can t find the number, just went off of measurements and hose positions, i think it was for a ford. I like the fact that electric fans give high flow when the engine is idling.
thought about changing airflow direction but didn't think it would be good trying to push it out when you are driving down the road.
my fans are on the inside pulling air in with a snug fitting shroud
KickerM
Site Supporter
Now that the motor is in the shop I can focus on actually rebuilding it! Plus its -20F below outside so when the shop is 30F; it is great inside! I have figured out that Bombardier built these things LIGHT, and that is an understatement...I will be adding some key gussets to the tub, to get it 50+ more years of service!
Anyone else have Bombi tubs that are cracked out from flexation?
I welded 3" angle iron down the sides of the tub to give much needed top frame support. It will make the entire snowcat more rigid from the motor cradle to the Differentials being able withstand the harsh demanding working conditions!
The second pic is the rear 2x4" tube cut off flush with the tub so the angle iron can extend past the old frame to make the new frame
The Last Pic is of the much improved access hatches, the blue is the old size the red is my New and Improved Access Hatches! I plan on making the new covers out of possibly 12 or 10ga so they can take some abuse, yet provide full access to the transmission and back of the motor if ever needed! The notches are for the Transmission mounts and Front Motor mount.
Blackfoot Tucker
KickerM, you have my condolences. It appears you've been bit, and bit badly, by the "project creep" bug.
I'll warn you, though it's probably too late, it can get out of hand very quickly, and I speak from experience.
Good luck!
KickerM
Site Supporter
Yeah this kinda started out as a floormat cleaning project...I think the project creep bug was a venomous millipede with the antidote coming from a traveling snake oil salesman...The only cure is to do it right and get all the way down to the bare ground and work my way back up....I have this other condition where when I do things they have to be done right, and only the best will do...no cutting corners!
KickerM
Site Supporter
So it’s been a while since I‘ve updated this thread, so things have been happening as funds allow and I finally got around to making some progress, I built some brackets to lift the motor; then I pulled the head to check to see if it had hardened valve seats, (required for unleaded gas) and it didn’t [emoji848], so I took it into the engine shop to have seats put in it and I get the call....your heads cracked...[emoji2959]!!! So after I ordered a new head, then I needed new head bolts....and my exhaust manifold was broke in 3 pieces; so I got a new one from MN Outdoors (Thanks Brad!) and before you know it I’m full into rebuilding the motor....
KickerM
Site Supporter
So it’s been a while since I‘ve updated this thread, so things have been happening as funds allow and I finally got around to making some progress, I built some brackets to lift the motor; then I pulled the head to check to see if it had hardened valve seats, (required for unleaded gas) and it didn’t [emoji848], so I took it into the engine shop to have seats put in it and I get the call....your heads cracked...[emoji2959]!!! So after I ordered a new head, then I needed new head bolts....and my exhaust manifold was broke in 3 pieces; so I got a new one from MN Outdoors (Thanks Brad!) and wouldn't you know it i'm committed into a full engine rebuild!!!
KickerM
Site Supporter
Not sure why the above post supersized, I used Tap Talk to post from my phone but I checked the website it is huge! Sorry for that! I reposted so it was normal sized!
KickerM
Site Supporter
I’ll try this, hopefully the pic isn’t gigantic!!! Time to check the rods and mains!
KickerM
Site Supporter
The oil sump in the pan seems to leak and from what I can tell the previous owner “tried” to fix it...several times; must have never learned in order to weld a leak you have to get the fluid out first...I think I’m going to start over with a new pan and fab up a whole new sump!
KickerM
Site Supporter
So I have through trial and error figured out that the GIANT pics are Original (3024x4032) sized, Medium (768x1024) are the "normal" sized ones on the forum and small (384x512) are like the last post...and if you have the VP pkg from tapatalk and post multiple pics at once it defaults to the GIANT (Original) pics! So sorry for the weird sized pics lately, just trying to use my phone as I don't get to a computer often...
What is everyone else using to post on here?
sno-drifter
I would add at least one support to that oil pickup tube. That's a lot of leverage and the tube is liable to crack and brake off at the oil pump flange. No Bueno when that happens. Think vibration and oil sloshing.
KickerM
Site Supporter
I was able to get the new oil pan and had a friend that’s better at TIG welding than myself weld up the deep sump, Ready for paint!
KickerM
Site Supporter
I got the soda blaster out to do the sensitive parts...basically everything I don’t want to risk the chance of a grain of sand getting into the engine. And I can say I was quite impressed with how good it did, although it does take more patience....then primed and painted with a 2000° engine enamel
redsqwrl
silly question, where did you find the thermostat.
I need change one in undies dozer. is it in that fan block?
KickerM
Site Supporter
It was in the box....lol! but the thermostat is behind the Fan pulley, 4 bolts hold it to the head, alternator tensioner and hyd pump tensioner are attached to the outside bolts
KickerM
Site Supporter
I better post the pics from last week when I was able to sandblast the rest of the parts, get it prepped and the first coats of engine primer on it!
