MODEL: Musk Ox
VIN: UNKN
MILEAGE: 999999
ALL TERRAIN VEHICLE,MUSK OX,BUILT FOR ABERDEEN PROVING GROUND BY WILSON,NUTTALL AND RAIMOND, MOBILE TRACKED VEHICLE,35 TON DYNAMONTER WITH AN ONBOARD WELDER/GENERATOR, 115 VOLT POWER,4CYL, WAUKESHA DIESEL ENGINE,(THE REAR SECTION OF THE MUSK OX HOUSES THE ENGINE AND TRANSMISSION,THE FRONT UNIT HAS THE CONTROLS AND HAS HEAT AND A/C, ENGINE FOR THE MUSK OX IS A CUMMINS 8CYL DIESEL, THE CAB HOLDS 3 PEOPLE AND CAN HOLD MORE IF NEEDED.(ESTIMATED WEIGHT FOR EACH PIECE IS 35,000LBS). NOTE:"CUSTODIAN WILL NOT LIFT LOAD AND THERE IS NO DOCK AVAIABLE. THE CUSTODIAN WILL ASSIST IN PUSHING THE UNIT ONTO A RGN TRAILER. THOUGH SOME CHARGES MAY APPLY IF LOADING TIME IS EXCESSIVE." ABSENCE OF ANY INDICATED DEFICIENCY DOES NOT MEAN NONE EXIST. (47881F70030001) (05-2507M)
THE CONDITION OF THE PROPERTY IS NOT WARRANTED.
Special Inspection Information:
"MUST CALL FOR AN APPOINTMENT TO INSPECT
OR REMOVE PROPERTY"
Please contact the custodian for inspection dates and times and for removal arrangements.
Successful bidders are cautioned that they will be responsible for loading and removal of any and all property awarded to them from the exact place where the property is located, as indicated below
http://gsaauctions.gov/gsaauctions/aucbystate/
Click on link then search South Dakota
VIN: UNKN
MILEAGE: 999999
OR REMOVE PROPERTY"
