Reply
Thread Tools Display Modes
  #1
Old 11-25-2009, 02:40 PM
Snowtrac Nome's Avatar
Default stuck vw intake valve
i've had an intake valve stick open on my snow trac twice now when temp drops down to around -15.the CHT. has never exceeded 250 since i put the gauge on and generaly when an engine over heats its the exhaust valves that stick the intake valve will free up when it warms up and woks fine otherwise other than a cracked guide i talked to a few aircraft mechanics they think its moste likely no upper cylender lube from unleaded gas a problem they ran into with aircraft motors desighmed to run off of high octain leaded fuel they added marvl mystery oil to fix the problem any other thaughts from some of the vw experts out there.
__________________
Don
1962 st-4
KL2ZF
  #2
Old 11-25-2009, 04:14 PM
muleman's Avatar
muleman muleman is offline
worn out farmer
muleman is just really nicemuleman is just really nicemuleman is just really nicemuleman is just really nice
Default Re: stuck vw intake valve
Valve stem u/s for the guide. Try a quart or 2 of kerosene in the fuel.
__________________
"The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government"
  #3
Old 11-26-2009, 12:33 AM
scooterd scooterd is offline
scooterd is on a distinguished road
On my 37 John Deere B, I add one qt of kerosene to ten gallons gas. It runs great no matter how hard I work it. When I really want to have fun, I switch tanks and run it on straight kerosene. You have to close the shutters on the rad and get the temp up, or it will stall and be a real pain to start. It's fun though because people can't believe that a gas motor runs on kerosene. T-nut can relate to this I'm sure.Someday we will meet in Rollag or New Rockford!
__________________
Never be afraid to try something new. Remember that a lone amateur built the Ark. A large group of professionals built the Titanic.
  #4
Old 11-26-2009, 04:56 AM
there is another engine desighned to run off both fuels thats a td19 international you started it in low compression and spark ignition than pulled some levers wich changed it over to diesel and compression ignition than there is the ldt 465 multifuel engine that will run off both gas and diesel using compression ignition only the injection pump has a compensator valve to automaticaly adjust for different fuel densitys
__________________
Don
1962 st-4
KL2ZF
  #5
Old 12-03-2009, 12:21 AM
fr73ed fr73ed is offline
fr73ed is an unknown quantity at this point
Quote:
I sense a death in the family soon...
fr73ed
  #6
Old 12-03-2009, 01:14 AM
JimVT's Avatar
JimVT JimVT is offline
My 35 B starts on gas and runs on stove oil.
  #7
Old 12-10-2009, 04:38 PM
Update i'm not usualy a believer in a mechanic in a bottle but since i started adding lead substitute i have had no intake valve problems.
__________________
Don
1962 st-4
KL2ZF
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Intake & exhaust mods johnday Trailers & Tow Vehicles Forum 30 03-25-2006 10:28 PM
Check valve going back to well pump? bczoom Home Improvement Projects, Appliance upgrades, Misc Household items Forum 5 03-07-2006 02:01 PM
Hydraulic Valve -- Rebuild or Replace? Melensdad Tools & Tractor Implements Forum 3 12-26-2005 02:08 PM
Tractor Hydraulic Valve question Melensdad Tractor Forum 17 12-13-2005 01:38 PM
