bushcaddy my new to me toy skidozer sv 250
bushcaddy
hello every one,, i really like this site, it has tons of information and useful tidbits for anyone.. here are some pics of my part restoration of my cat, its a 72 bombardier skidozer sv 250 st 300 six all manual no electronics or hyd, point type distributor, just what i wanted. when looking at pics ul notice that spindals are not set properly, cause for hard steering , any way im going throught it real good. real hard time finding info for this machine. any pointers send them this way.
thx:smile:
bushcaddy
before, during reconstruction and rebuilt. electrical, body, sheet metal , steel , tracks , bearings, brakes, etc etc. enjoy the pics.
300 H and H
Hard steering can mean worn out brake bands in the differential.
The oil should NOT be ATF transmission fluid. Use universal tractor transmission, brake, hydrolic oil, SAE 20W..
There is a pump belted to the drive shaft that puts oil on the ring and pinion gear. Make sure it works. many of these machines ate Ring and Pinion sets with AFT. Lube pumps caused some failures as well.
One of the members here sell parts for these.
bushcaddy
Re: bushcaddy more pic playing with torsion suspension
spent the whole day r and r bearing races, and grease, alo heck of a job pulling off those spindals, did a re alligment on them:doh:
painting wheel tomorow
nikos
bushcaddy
Spent the whole day r and r bearing races, and grease, alo heck of a job pulling off those spindals, did are alligment on them painting wheel tomorow.
KickerM
Site Supporter
Hey what did you use for a heater? Looks like a good one?
300 H and H
Be sure to check your front flexators, the swing arm front suspension, for a "set" that will allow the front wheels to toe out, and make your tracks come off easily... These are filled with a elastomeric compound that has a limited life span, especially if track tension is left on in the off season. Common problem, usually field repaired by adding a block of steel to the frame inboard of the swing arm, to keep it parallel with the frame, and no toe out of the front wheels..
KickerM
Site Supporter
I've been advised to use CAT TO-4 Spec fluid in my Diffs... Ziegler Cat sells a 5 Gallon bucket of their brand for $65
