Lots of water usually clears up the initial symptoms
Yes. Try lots of water before you eat the stuff too, or all the time. I have found that helps with colds and about everything. The sewer pipes in a house work better the more water flows through them.
Lots of water intake causes/or allows the kidneys to do their job filtering the blood. Less kidney operation cause stuff to build up in the blood. During sleep kidney fuction is said to decrese by up to 50%. I think this cause/allows something to build up in the blood that puts you under/to sleep.
Cure in the Cause
Or
History Is behind Us
It's recorded, that many years ago, in the history of China, there was a rule in medicine, that a person was not allowed to go into a human body, deliberately. If a person's body was laid open due to injury, observations could be used to better man's understanding, but a deliberate compromise of the body's protective housing was not tolerated, for a period of hundreds of years. In a world of cause and effect, the reason for such a rule, the events leading up to the necessity for such a rule should be revealing.
At the moment, when a person is revived due to electrical cardiac stimulation, it appears to be a major medical achievement, on TV, in the media. Yet, follow-up studies show that many times the person will die a few days later from the same problem when no one is around.
Recent human transplant experimentation shows us that our bodies do not except organs unlike our own. Some foreign types survive within our bodies longer than others, but eventually the transplant recipient dies due to his immune system failing. This is a fact, is it not?
Is not a persons blood a fluid organ flowing within a system of veins and arteries? We know we can avoid certain problems associated with blood transfusions by selecting a certain type. But are we failing to recognize many problems which take longer to show themselves? Such as AIDS? If the donors blood is rejected by the receiver, how long would it take for the receptor to lose the battle against the foreign invasion? In medicine, there is a rule of doing no harm. That means, if a child does not die today due to a blood transfusion, it may look nice, and make a lot of people happy and wealthy for the moment, but if it causes harm to many down the road, it's not a good thing.
Tuberculosis/consumption is a problem that comes about due to a person not understanding the importance of sleeping in a raised bed. It is associated with the Cowboys, street people, and others who do not see sleeping raised as a priority. Sleeping on the ground wastes energy through dissipation, which the body would use in other ways, leaving the body in a weakened condition, susceptible to colonization, and therefore able to play host for the incubation and dissemination of unwanted parasitic lifeforms.
Human history tells of many plagues brought about due to man's ignorance, such as, when rodent populations in an area become too dense, the air becomes unhealthy due to too many woodstoves in a stagnant area, or when doctors practicing on corpses move from that room into the operating room without due consideration. When these problems arise, in the end the cure is found in the Cause. The cure comes about due to a change in our behavior. We stop doing the wrong thing that we recently began doing.
The study of Magnetrition points out that previously it was unknown, even to doctors, that all warm-blooded animals must reorientate periodically in a magnetic field similar to the Earth's because many of their cells obtain a required degree of circulation within them only by keeping a magnetically migrating organal moving. With this new understanding, comes many questions. Such as, how important is it that blood be kept moving through our body for it to be kept healthy?
Why is it, that the inhuman practice of keeping oneself and or others alive through the use of another persons body parts, not recognized as cannibalism anymore? Is it like being led to see freedom fighters as terrorists? Are these symptoms of being capitalist diseased?
I don't think giving more money to doctors and their pharmaceutical corporations will cure problems such as AIDS, but I would not rule it out as a cause.
It used to be, only some doctors were quacks. But now, with the AMA, they all have to be like their leader.
DO I HAVE A LYMPHATIC FEVER?
OR
DOCTOR WHO HAS TWO HEARTS?
1) Is the cardiovascular system used to transfer heat, thus, controlling the body's temperature?
2) By closing capillaries and decreasing blood flow, can the cardiovascular system, by choice, cause the body's temperature to increase, purposefully?
3) Does the lymph system rely on body movement and temperature, to maintain normal function?
4) Now, in human beings, can an increase in the body's temperature, and/or movement, cause "rapid lymphatic function?
5) Is breathing, (lung and diaphragm function), utilized in lymphatic pumping?
6) Is "flight muscle function" utilized in cardiovascular pumping?
7) Does the heat of the chest and abdomen add to movement within the lymphatic heart, and like the draft of a chimney, cause a depression, or suction, in the outer lymphatic system?
8) Does the cardiovascular system utilize the constant function of flight muscles to maintain blood circulation?
9) Can the lymph and cardiovascular systems be found less divided, or less distinguishable, at a earlier time in our evolution, and was the lymphatic heart utilized for circulation within the body deprived of flight muscle function?
10) Can looking at the anatomy of the sphinx moth, be like looking millions of years into our past, as it is when we look at the stars?
* Cells alive and about to divide are warmer, and will rise to the top of the lymphatic heart faster, to be removed from the system and checked by the body's filter system.
ORNITHOL
1) Are the sections between valves in the lymph system, actually small digestive tracks, that begin to digest the waste from each cell, close to its source, and then return their product, (lymph=reusable compounds plus compounds to be filtered by the kidneys), by way of the lymphatic heart (thoracic duct), to be blood system?
2) As with our main digestive track, (stomach, small and large intestine), do all lymph tracks/sections require within them a mixture that contains pockets of air or gas, essential for chemical break down and absorption?
3) Does/would the presence of air in the lymph system explain another reason for lymph to have to pass many valves before entering the blood system?
4) Does movement of each lymph track aid in digestion, as the wave aerate the water and humidifies the air?
5) Is it the job of the lymph system, to carry white blood cells as they move up stream, sensing and tracking abnormal cells by their excretion into the lymph system, and does a job half done move the abnormal cell to a place where it can grow and multiply?
6) Can the body, with the help of the lymph system, move or give, a foreign or abnormal cell, a place to grow and live, (such as a mole), for observation and close control, or be moved to a place deep, to become a vital organ when viewed as a symbiotic partner?
7) Must a good understanding of our working, evolving body, take into account this fact; that our cells grow best when moving, or change to adapt when not.
