Reply
Thread Tools Display Modes
  #41
Old 09-20-2017, 11:01 PM
snow snow is offline
Junior Member
snow is on a distinguished road
Default Re: New Thiokol Spryte
rebuilt transmission
  #42
Old 09-20-2017, 11:10 PM
Junior Member
I am desperately looking for weatherstripping tape, the rubber coated fabric found between the cab and the frame and between the gas tank and its steel cover. Out of luck. Anybody can recommend something?
Also looking for foam insulation to glue in the cab: panels, roof. Any ideas / suppliers you would recommend?
Thank you,
JB
  #43
Old 09-21-2017, 01:19 AM
zspryte zspryte is offline
zspryte is on a distinguished road
I used 1 inch thick polyethylene closed cell foam (2 lb cross linked). Polyethylene does not absorb water - plus it is closed cell. I bought white foam for the ceiling, but found out it yellows after a while so I put marine grade upholstery it before I installed it. To attach the upholstery to the foam and the foam to the cab, I used 3m super 90 spray adhesive. I used a router to cut a step around the edges of the foam on the side facing the aluminum skin. This made it lie flat on the supports and gave me a place to tuck the upholstery fabric into. On the doors and bottom sides, I got black foam and did not put upholstery on it. Around the bottom portion of the cabin I put in a Mylar coated sound deadening material on first and the foam on top of it. The foam on the ceiling has eliminated the tropical rains (condensation) I used to get during winter inside the cab. If you can pick the panels up, you will save $. The stuff comes in big sheets - 4'x6' and is pricey so look around. There is a company called "Foam Factory". It has multiple names and the price varies depending upon which web link you use. You might find it cheaper closer by.
First pic won't load rotated - hum!
If you are going to be around BV this weekend, PM me.
  #44
Old 09-21-2017, 02:10 AM
nikos's Avatar
nikos nikos is offline
nikos is on a distinguished road
zspryte speaking
a) new electronic distribution
b) rebuilt transmission
c) I used 1 inch thick polyethylene closed cell foam (2 lb cross linked). Polyethylene does not absorb water - plus it is closed cell. I bought white foam for the ceiling, but found out it yellows after a while so I put marine grade upholstery it before I installed it. To attach the upholstery to the foam and the foam to the cab, I used 3m super 90 spray adhesive. I used a router to cut a step around the edges of the foam on the side facing the aluminum skin. This made it lie flat on the supports and gave me a place to tuck the upholstery fabric into. On the doors and bottom sides, I got black foam and did not put upholstery on it. Around the bottom portion of the cabin I put in a Mylar coated sound deadening material on first and the foam on top of it. The foam on the ceiling has eliminated the tropical rains (condensation) I used to get during winter inside the cab. If you can pick the panels up, you will save $. The stuff comes in big sheets - 4'x6' and is pricey so look around. There is a company called "Foam Factory". It has multiple names and the price varies depending upon which web link you use. You might find it cheaper closer by.
The Following 3 Users Say Thank You to nikos For This Useful Post:
redsqwrl (09-21-2017), snow (09-21-2017), zspryte (09-22-2017)
  #45
Old 09-21-2017, 10:28 AM
Junior Member
Thank you Nikos!
I still can't figure out how to rotate the photos, and the website crashed several times as I was trying to upload the photos.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
67 thiokol spryte savetrax Snowcat Classifieds (For Sale / Wanted) Forum 4 04-03-2016 05:34 PM
Thiokol Imp or Spryte Mike8623 Snowcat Classifieds (For Sale / Wanted) Forum 9 03-07-2015 06:16 PM
Thiokol Spryte in MN. anthonydoldd Snowcat Classifieds (For Sale / Wanted) Forum 2 02-05-2015 08:46 PM
WTB Thiokol Spryte northern lights Snowcat Classifieds (For Sale / Wanted) Forum 4 09-03-2014 08:59 PM
Thiokol Spryte 201 JCGRAY THIOKOL/LMC/DMC Technical Issues Forum 5 04-23-2007 12:51 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
