Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #1
Old 09-12-2012, 07:27 PM
brianf brianf is offline
brianf is on a distinguished road
Default snowtrac sprockets
what is the availability of sprockets for snowtrac machine, believe 1967, also did they come with soft top or removable piece on roof, just looking at this machine to see if it is worth buying
  #2
Old 09-12-2012, 10:32 PM
Snowtrac Nome's Avatar
Default Re: snowtrac sprockets
the sprokets can be cast member jimvt has some one who can duplicate the old lyndon sprokets for the 2 band machines the north pole foundry can also cast new ones based on the origional pattern for both the three band tracks and 2 band models the early snow tracs had a canvas cover over the hole in the top most of those have been replaced with py wood and 300 h&h did one better by putting a metal cap over the ply wood to seal it up real nice.
__________________
Don
1962 st-4
KL2ZF
  #3
Old 09-12-2012, 10:35 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
coach loafer may have molds as well.
  #4
Old 09-13-2012, 01:55 PM
this machine is 2 band track, but with sprocket issue may not be worth buying unless I had parts machine, some one used light plexi glass in roof, will never take snow load with out breaking
  #5
Old 09-13-2012, 02:24 PM
what does he want for it to have sprokets made is about 900 bucks a set of 4 brad also has a water jet and can cut them out of uhmw with a good pattern i had entertained having him do some for me but it cost way too much unless i cand get a bunch cut at the same time. because the time is all in the set up once the machine is set up than every set after that will drop the price get some pics so we can see the wear the teeth will start to break off between 5/16 inch and 1/4 inch other wise the may look thin but will function just fine
__________________
Don
1962 st-4
KL2ZF
  #6
Old 09-13-2012, 10:50 PM
he is asking $7000 obo, machine is very clean , needs sprockets and probally tires, but everything else seems ok. little things to fix but nothing major,
  #7
Old 09-14-2012, 01:18 AM
JimVT's Avatar
JimVT JimVT is offline
tires are harder to find than sprockets.
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #8
Old 09-14-2012, 01:03 PM
i don't know thwer are some nice machines in kenai that are ready to go for that price
__________________
Don
1962 st-4
KL2ZF
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
My New Sprockets trackmaster Snowcat Adventure & Usage Forum 0 03-18-2012 11:56 AM
4T10 Sprockets dlmorindds Snowcat Restoration & Modification Projects Forum 2 06-03-2010 08:09 PM
need value of 601 sprockets mkntrakes Snowcat Repairs, Parts & Problems Forum 2 01-30-2010 02:59 AM
Raidtrac 618 > need DRIVE SPROCKETS djgerman Snowcat Repairs, Parts & Problems Forum 2 02-05-2009 08:35 PM
601 drive sprockets darryl Snowcat Restoration & Modification Projects Forum 3 10-17-2007 06:56 PM
