I thought Ham operators were all Morse code but now I see they have mics . Is this a basically super duper CB radio ???
I admitt I know nothing about this stuff .
I remember my CB license was KXY-7269. A lot of us were pissed when the crazies overwhelmed the airwaves, and many of us just got out of the hobby.HAM radio has significantly more frequencies. And, more power ranges. Even back in the 30's and 40's, my Grandfather talked on HAM. He was also exceptional with Morse code.
CB is a limited set of frequencies. It is also limited in power(I want to say 3.5W, but not sure). CB used to require a license. In the '50's-'70's, my Grandfather was "The Old Cowpoke, KLA-1624". Even early '70's, my Dad got his CB license.
Everything went CRAZY though in the early '70's with the CB craze. CW McCall, the trucking craze. FCC couldn't keep up. They finally did away with licensing.
geeAl i would love to bash your krusty over the air to would be lots of fun however if you are interested take the test for the nocode tech license and i can help you find and program the equipment if thee is an irlp node in your area than you can call me up and give me a bad time about having the better snow cat. and as i have talked with folks in idaho i'm betting there is a node in your aera.
gosh what do you expect from a krusty owner if you had read some other post's a node station is where you have a radio conected to a computer in the case of irlp that is a way of recieving signals from other radios converting the signal to data than sending the signals through the inter net and rebroadcasting them at the other end through another node station.i hope i explained in laymans terms that all can understand things do get alittle more complex with other modes and reflectors i just wanted to keep it simple for those who are interested and are clueless hopefully peaking some interest. the sytem is pretty easy for the general operator just key the mike .the neat part of voip comunications comes with different ways of accessing it through the internet such as with an i-phone or a home computer than you don't even need a radio to bash my snot trac
ps which is by the way still running good
That's discouragaing It Took me a long time to work a computer.Ham radio is just like computer. If you don't like the answer here or the folks on this channel you can go someplace else and find someone else.
I have a couple questions on the two meter.
I was told it is like a partyline .Is that correct? I mean the old phone kind .So you wait your turn on that frequency?
I notice some have scanners built in, Is that for scanning your frequencies for calls?
Jim
When I lived in a different part of the country, there was a house with HUGE antennas. I'd say one was at least 30 from the ground, maybe 50 feet wide and 10 feet tall? Another was situated the other way, maybe 20 feet wide and 30 feet tall. And there was one that wasn't like a standard antenna, but more like a wire strung in a straight line, maybe 250 long? And then the usual antennas, straight up things maybe 50 feet up
What was all of that?
I was not aware of the "Wilderness Protocol" frequencies, but with just a quick Google search, I learned its history, and will be programming the simplex frequencies into my radios. I will also write a short script on the protocol and remind/introduce folks about it during our many nets in this area. Thanks a lot!Nice, have a good fishing trip as I love to fish as well. Also, have you heard of "Wilderness Protocall"? On 2 meters it's the simplex calling freq. (146.520) and 446.000 on 70 cm. On the top of every hour or every 3 hours depending on the area and your battery power you listen for other simplex callers in your area. If you can not hit a repeater call out on these freq's for help on the top of the hour.
73's
Josh
