Reply
Thread Tools Display Modes
  #1
Old 12-07-2017, 01:04 PM
Snowman48 Snowman48 is offline
Junior Member
Snowman48 is on a distinguished road
Default Replacement Fluids
Hi All,
I've been trying to find a replacement fluid for my 2003 SW48. The recommended brand does not exist in my city(or maybe not at all) and the shops I've called don't have any suggestions. What should I use for the C6 transmission oil?
My unit has a delay when shifting into reverse from any gear...worse when the unit is cold....tend to get better after I've been plowing snow for awhile. Transmission oil looks clean and smells normal but thought I would start there.
Pic of recommended fluids and capacities chart from service manual attached.
Thanks.
  #2
Old 12-07-2017, 03:07 PM
rockhead's Avatar
rockhead rockhead is offline
rockhead is on a distinguished road
Default Re: Replacement Fluids
I bet your local Caterpillar dealer would have an appropriate substitute.
  #3
Old 12-07-2017, 05:51 PM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
If you have a John Deere dealer near, I'm fairly certain that low vis Hy-gard is a cross for the winter Donax. The parts counter should be able to confirm.
  #4
Old 12-11-2017, 06:14 PM
Junior Member
Thanks guys...will check it out
  #5
Old 01-26-2018, 06:52 PM
Junior Member
Was able to find at local Chevron bulk supplier. No other dealer in town could cross reference the Shell Donax....crazy.
  #6
Old 01-26-2018, 09:56 PM
IMP IMP is offline
IMP is on a distinguished road
I use CAT TDTO 30wt oil in my differential on my J5. It should be the same diff as your SW and steers good in winter and fall temps
__________________
The Following User Says Thank You to IMP For This Useful Post:
Snowman48 (02-01-2018)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ski dozer 252 rear fluids. Nate b Snowcat Repairs, Parts & Problems Forum 5 11-24-2012 11:36 AM
Hip Replacement tommu56 Jokes_Forum 4 02-10-2011 06:30 PM
IMP motor replacement mwolfca THIOKOL/LMC/DMC Technical Issues Forum 2 01-04-2011 12:14 AM
Replacement for Jay Leno BigAl Political Debate Forum 6 06-23-2008 12:23 PM
Grouser Bar Replacement kgracey Snowcat Repairs, Parts & Problems Forum 13 11-03-2007 09:40 PM
