Reply
Thread Tools Display Modes
  #1
Old 10-12-2017, 03:36 PM
Sno-Surfer's Avatar
Sno-Surfer Sno-Surfer is offline
Sno-Surfer is on a distinguished road
Default Pontoon tune up
Well it's time for my Tucker initiation. I was getting pretty good at replacing cotter pins and some rollers last season but now it's time I take those pontoons off and get some work done to them before I pile on the miles this season. Seems like all Tucker owners also have shops and seem to know what they are doing. Well I have a driveway and a couple phone numbers of sno cat experts and I've been able to get them off myself with a floor jack and furniture dollies. But the first one I sure scratched my head a lot. 2nd one was much easier to remove. I hope getting them back on goes as well....
The Following 3 Users Say Thank You to Sno-Surfer For This Useful Post:
4TrackCat (11-22-2017), jim slagle  (10-12-2017), Kristi Kt-4 (10-12-2017)
  #2
Old 10-12-2017, 03:38 PM
Sno-Surfer's Avatar
Default Re: Pontoon tune up
Sno Drifter says he runs the wood sticks the other way but with those shimming boards, this worked out fine.
One question. Once you get the small cap off the end, you then need to take the axle nuts off but there is a cotter pin in there. I cut them out to get it off but how do you reinstall that cotter pin? Seems the walls of the bearing housing are in the way. One side was wired on and I can see why but if I wanted cotter pins, how do you do it?
The Following 2 Users Say Thank You to Sno-Surfer For This Useful Post:
  #3
Old 10-12-2017, 03:39 PM
Sno-Surfer's Avatar
This journal was loose and I'll need to get it welded back on. How do my bottoms look to you experts?
  #4
Old 10-12-2017, 03:41 PM
Sno-Surfer's Avatar
jim slagle  (10-12-2017), Kristi Kt-4 (10-12-2017), nikos (10-15-2017)
  #5
Old 10-12-2017, 03:42 PM
Sno-Surfer's Avatar
  #6
Old 10-12-2017, 03:44 PM
Sno-Surfer's Avatar
One of these nuts have a seal on them. One of them is damaged, you can see it next to the good one. I don't see any part # on it to get it replaced. Any ideas? Not sure how much it's needed.
  #7
Old 10-12-2017, 03:45 PM
Sno-Surfer's Avatar
I see someone made their own axle extension at some point. Looks better than the original.
  #8
Old 10-12-2017, 03:47 PM
Sno-Surfer's Avatar
Well these loaded upside down. Don't quite understand why. Blue tape are areas that need some welding. My good friend brought over his trailer this morning so we can load them up and bring them to the welding shop. My truck is in the shop too so it was nice to have a little help with this.
GlacierSean (10-12-2017), jim slagle  (10-12-2017), Kristi Kt-4 (10-12-2017)
  #9
Old 10-12-2017, 05:50 PM
sno-drifter sno-drifter is offline
sno-drifter is on a distinguished road
Bend the cotter pins to a gentle radius and work them into place. I would not worry about the seal on the nut, it is there for use in a truck which uses the 90 wt. oil to lube the axle bearings. Pack the bearings with good quality bearing grease. BTW, that hammer is way to small for any serious cat work.
The Following 3 Users Say Thank You to sno-drifter For This Useful Post:
3512b (10-13-2017), Northcoast (10-13-2017), Sno-Surfer (10-12-2017)
  #10
Old 10-15-2017, 04:19 AM
nikos's Avatar
nikos nikos is offline
nikos is on a distinguished road
Sno-Surfer
The Following 3 Users Say Thank You to nikos For This Useful Post:
4TrackCat (11-22-2017), Sno-Surfer (10-15-2017), snow (10-18-2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tune up on my 601 wesley THIOKOL/LMC/DMC Technical Issues Forum 1 10-03-2015 04:56 PM
JW73 Tune Up ColeMac Snowcat Repairs, Parts & Problems Forum 2 07-29-2012 11:25 AM
Imp Tune-Up cloudcap Snowcat Repairs, Parts & Problems Forum 13 11-11-2010 07:26 PM
A catchy little tune HarryG Open Forum 1 09-11-2009 09:55 PM
Favorite 80's Tune Deadly Sushi Junkman's Corner 54 05-02-2008 10:05 AM
Copyright 2002 - 2017 www.ForumsForums.com
