Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Trailers & Tow Vehicles Forum
Reply
Thread Tools Display Modes
  #1
Old 10-10-2019, 07:22 PM
sleddogracer's Avatar
sleddogracer sleddogracer is offline
sleddogracer is on a distinguished road
Default transmission swap
I recently bought a converted 1975 chevy bus camper - it's a C60 series with a 24500 GVWR - it's had a fresh LS7 454 put in it, but still has the original 5 speed manual transmission - I'd like to put a more modern automatic transmission in it - perhaps a 5 or 6 speed - I imagine if enough money is thrown around, anything is possible, but I'm on a budget - is this swap possible without a LOT of hassle or back breaking expense?
  #2
Old 10-11-2019, 08:40 AM
300 H and H's Avatar
Default Re: transmission swap
You need to find a truck salvage yard. Although not common, some of the trucks of this vintage were produced with Allison automatic transmissions. I do not believe it would be all that hard to convert your bus to one of those. Do not use anything from an automobile, as the GVW of your bus would easily exceed the torque ratings of any auto transmission, and result in a very short life span..
Not sure if any of the Allison trans for this application had an over drive or not how ever. Of course you might not need one with OD anyway.
Hope this helps
__________________
Snow trac ST4 #267
  #3
Old 10-11-2019, 11:36 AM
Hope this helps
thanks Kirk - I know I need a transmission capable of handling a vehicle with a 24,000+ GVWR - I do have a 4 speed trans in a 14000 GVWR truck - I'm going to check to see if that would work in the bus or if it can be upgraded to do the job - the trans is 3 speed + over drive - the 14000 GVWR truck was running well until 2 black bears smashed the driver's side window and trashed the interior of the truck - seats, dash, door panels etc- nothing of use left in the interior - the fresh motor it had now powers my pickup, but the transmission is still there - the bus has a split rear end, so that might be a help for the transmission
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bombi motor swap snowcatt Snowcat Restoration & Modification Projects Forum 2 07-10-2016 10:02 PM
needs motor swap on a J5 sleddogracer Snowcat Restoration & Modification Projects Forum 4 05-07-2013 06:31 PM
Can We Swap Obama for Chavez? CityGirl Political Debate Forum 13 02-19-2011 02:45 PM
SW 48 Diesel swap NSSW48 Snowcat Restoration & Modification Projects Forum 3 06-09-2010 12:00 PM
Motor swap ? cooper Snowcat Restoration & Modification Projects Forum 33 04-08-2007 12:55 PM
Copyright 2002 - 2020 www.ForumsForums.com
