Rear/front weight
Mith
The Eccentric Englishman
What do you all use for rear/front weight? How much weight do you use?
I've seen some pretty fancy weights made from concrete formed around 3PH pins, even saw one where someone had formed some lead about some pins I believe. And Johns forklift weight (which he still hasnt finished.....) Also those branded weight boxes, anyone use them? Also hear about people using things like RCs for weight, but it seems to me a weight box would be better, less swinging room.
I picked up some steel plate the other day, going to use it as rear weight. For front weight I have a big block of cast iron welded to a reciever.
The plates are about 5/8" thickness. What is shown in the picture weighs about 120 pounds. I'm hoping that the shape means I can tuck it away, under the operator area for example. Obviously my equip is smaller, so less weight needed.
All I use is my box blade. I do have a carry-all + pallet + sandbags if I need to work in a more confined area but to date, that hasn't happened.
Jim_S
Same here. I have filled rear tires and use either the box blade or the tiller for weight.The box blade is @ 600 pounds. The tiller is less but it is closer coupled so it is easier for tight places.
Jim
Grooming Snow
This is something that I seen in Farmers Hot line , it's called Rim Guard Tire Ballast non- corrosive here is the web site www.rimguard.biz . The only thing is that it can make it harder to change tires
