variator adjustments
teledawg
whenrebuilding a variator should the heavy springs be totaly compressed when reassemblying ??
Read this entire thread by Lyndon on the Variator:
http://www.forumsforums.com/3_9/showthread.php?t=4113
And specifically post No. 18:
http://www.forumsforums.com/3_9/showpost.php?p=42166&postcount=18
To answer your question directly, I assume that you are referring to the W 20112 and W 20113 pressure springs that go on the ST 7021 eyebolts.
Here is a quote from the Aktiv "Repair Instructions for the variator":
8. Assemble the pressure springs as shown in fig. 8 and 9. Tighten the nuts (a) until the springs are completly pressed together and then ease off 1-1/2 turn. Hold the nut (a) with a wrench and tighten the locking nut (b) to a torque of 15 kpm (147 Nm or 108 lbf*ft)) and lock it my means of three punch marks in the ST 3006. Screw the eye bolts ST 7021 as much as indicated.
You can download a .PDF copy of the manual that contains "Repair Instructions for the variator" starting on page 30 here:
http://www.goldcordmine.com/manuals/Snow Trac (17 manuals)/Manual 1963 full.pdf
Here is a useful post that contains links to all that any ST4 owner should know:
http://www.forumsforums.com/3_9/showpost.php?p=125019&postcount=2
Good luck and post some pictures of your progress :weneedpic
