Every now and then you find a great deal on a great product. Here I have found such a deal and wanted to share it with you all. Blast cabinets are a pretty simple system but some companies charge an arm and a leg for them. To me the biggest reason is most likely the fabrication involved in building the actual cabinet everything is housed in. Here it looks like this company has been able to by pass this cost by using pre made oil drums. They have 3 models from what I can see on there site. 55 gallon, 85 gallon and dual connected 85 gallon drum (170 gallon). Check them out if you need a great cabinet at a low cost.
The 55 gallon blast cabinet is $299 and comes ready to work. All you need to do is hook up your air compressor!
http://www.barrelblaster.com/
Since I was told not all members go to the snowcat section I will post this in another part of our forums.
