In my opinion, I think you would definitely be glad if you did use Por-15. When I was researching a "affordable" coating for my grousers, Por-15 "I felt" was the best, considering the cost and durability that it provides. I do feel if you want the best protection it can provide, the metal "should" be media blasted first even though Por-15 says you don't have to. I put only about 100 mi on my grousers before winter was over, however, the only place the coating wore off was on the surface of the "center" of the grouser that actually comes in contact with ground. I don't think there is any coating that would last in that area. Por-15 goes a longggg way, I used only 2qt of the coating to do all my grousers which I think cost about $100, and that's not bad at all considering some of the other coatings that are out there.
My next restore is a 1973 Tucker 542 and "if" I stay with the steel tracks I will definitely use the stuff on the tracks. I now use Por-15 on anything that I want black. I also would only brush it on, not spray it (I've tried both) when it dries, it shows NO brush marks.
