snow trac heater/defroster
JimVT
seen this the other day and noticed one line going as defroster. that should keep any moisture off the windshield.
JimVT
if your a trac owner you know keeping the condensation off the window seems impossible at times. this blower /heater should solve that problem.
that is a 28000 btu sterart warner 10530 multifuel heater. they make good heat but are gas hoggs
JimVT
you can see the tank for it behind the oil cooler. a very large one. it could be shared with the engine. i'll have to look next time i'm at his home.
