Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #1
Old 12-13-2013, 12:58 PM
Tracks Tracks is offline
Junior Member
Tracks is on a distinguished road
Default 1975 SV200 Project
I am newer to this forum and enjoy the postings and information posted by more experienced owners, thanks! I am currently working on a SV200 I purchased from Bogie last year. He was nice to include in the purchase the back portion of a SV252 full cab. It turned out to be rough cut just right for this application. There are now benches on both sides with lockable storage underneath. I am thinking about installing joy stick steering (from Bogie) and fuel injection.
The Following User Says Thank You to Tracks For This Useful Post:
Nikson (12-23-2014)
  #2
Old 12-13-2013, 09:46 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Default Re: 1975 SV200 Project
I almost forgot about that one. Seems to me that was a challenge to load if I recall correctly
Merry Christmas
__________________
The Tracks you leave today, Will lead you to the future!
  #3
Old 12-22-2014, 11:10 AM
Junior Member
I am slowly working on the SV200. Took in out for a quick spin and found out quickly that about 7 inches of ice is not enough to support the machine after 3 hours, one chain saw a bobcat and one 8000 pound winch it was out.
I was a huge undertaking loading the machine and getting it balanced, but made it home ok.
  #4
Old 12-22-2014, 11:18 AM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
Quote:
Merry Christmas
Well, I am glad to see that I am not the only one to pull out of the compound uniquely loaded. Not sure I ever grabbed a photo. (that is a good thing)
I love the cribbing,
that cab looks very nice on there.
  #5
Old 12-22-2014, 11:22 AM
Junior Member
After this I pulled all the wheels off to check the bearings and replace the tires. Looks like it is getting new tires, bearings, races and seals while it is apart. Drained all of the fluids and changed them. Water only in the rear diff so that was the first one to be changed.
  #6
Old 12-22-2014, 11:23 AM
redsqwrl's Avatar
Quote:
I am marginally interested in Ice sheet data.
Couple of dumbish questions:
Did you drive out and park and the ice failed as it sat there, Or did it fail while operating, as in the wake caused a ice sheet failure.
The Army published some ice sheet data and the studies identify the compressive strength of the sheet is important as the thickness.
Dark Ice or the porous white stuff.
Mike
  #7
Old 12-22-2014, 11:29 AM
Junior Member
Good questions, Covered in about 6 inches of snow, underneath the ice was clear. I was moving about 5-10 mph when it started to crack and drop rear first. I am sure it was the wake due to the high speed of this machine, the wake was enormous. I should read up on the ice requirements, thank you for the suggestion. Did Bombardier make a floatie option?
  #8
Old 12-22-2014, 01:17 PM
Snowtrac Nome's Avatar
all I have to say is that thing must have a heavy foot print. I have had they snow trac on as little as 3 inches of ice ,rescuing a crashed cessna170b, that was with an 18 foot car hauler attached to it. the Thiokol 2100 has sat on 8 inches ,and not fallen through , the bottom was better than twenty feet of water under me both times. mu 76 chevy pickup with rust and 33x1250's would stay on top at 4.5 inches fell through at 4 inches . I spend quite a bit of time on top of the ice around here but it is salt ice which is more pliable than fresh water ice.
__________________
Don
1962 st-4
KL2ZF
  #9
Old 12-22-2014, 08:35 PM
MNoutdoors's Avatar
I think I figured out what the problem is you must have fill the gas tank with
leaded fuel if you would have used unleaded I think it would have much lighter I do remember that extra cab being fairly heavy.
But remember I did get hit in the head last week so I could just be jabbering
All is well that ends well
__________________
  #10
Old 12-22-2014, 09:25 PM
good one Brad
__________________
Don
1962 st-4
KL2ZF
  #11
Old 12-23-2014, 11:32 AM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
This guy can share your pain:http://www.myfoxtwincities.com/story...succumb-to-ice
__________________
Formerly Blackfin4Bluefin
  #12
Old 12-23-2014, 03:22 PM
Nikson's Avatar
Nikson Nikson is offline
Nikson is on a distinguished road
Wow, now I dont feel bad about sinking my 1402 under water on the first run as well, although I didnt know I was atop any water at all...
Its a great lesson and almost an adventure having to pull something out like that, hoping that it all will go good.
As far as ice data - this is what I've experienced a bit myself and had heard other guys talking about...
1 inch and above will hold a human (although I guess depends how heavy they are )
2 inch and above should hold a regular size ATV (quad)
4 inch should hold a regular car / light size SUV
6 inch should hold a full size truck
8 inch and above should support a F-450 Ford truck size vehicle and above...
but all those number are PER conditions and per circumstances, I for one, like to just keep things ashore if possible, personally - I dont mind getting into the icy water, must be the russian blood in me... :) :) :)
p.s. presence of a hot SAUNA is a must in those conditions
__________________
You can find me on Youtube & Instagram
aka "BudNixon"
"Everything will be okay, and if it not okay - its not yet everything!!!"
  #13
Old 12-23-2014, 07:01 PM
redsqwrl's Avatar
I use this:
http://www2.mvr.usace.army.mil/Water...ce/safety.html
  #14
redsqwrl's Avatar
and this:
http://www2.mvr.usace.army.mil/Water.../ice_load.html
  #15
Old 01-04-2015, 12:49 PM
Junior Member
I was at Boggie's Friday and picked up all new bearings, races and seals. I also picked up everything to convert it over to joystick steering, this should make it easier too use. A week ago I got 8 new tires this should just about make to lower end maintenance free for a few years. Maybe my wife will be more interested in driving it.
  #16
Old 02-02-2015, 09:18 PM
Snowstorm Yukon's Avatar
Snowstorm Yukon Snowstorm Yukon is offline
Junior Member
Snowstorm Yukon is on a distinguished road
Howdy Tracks, your cat looks sad in the water !! looks like less than 7" of ice tho ? I'm doing total rebuild on my SV200 also,have posted pics last year, just starting to do a bit more now, have engine tranny in, engine wired, new rad, new heater. I like your extended cab, can you remove easily if needed? Some pics enclosed. I just came back from working on ice road in NW terr, using Bombardier BR350, we needed 17" of ice before they let us on to plow snow off.
Bill
  #17
Old 02-14-2015, 10:14 PM
Junior Member
Love the restoration pic's, seems like every time I take something down that far I never get it done. Answers to a few previous questions I was on the move when I crossed the ice. I measured the ice from the pieces I had to cut at the edge that probably made it seem thicker. The cab can be removed via chain hoist, time to remove about 20 minutes and 4 bolts for now. It is quite heavy but I like have the space when going to the cabin, its about 3 miles in and can be deep snow for Minnesota.
  #18
Old 02-15-2015, 12:23 AM
Junior Member
Hi tracks. Yes doing a complete rebuild is time consuming but fun, don't have to rush things!! Got cab on and got most things hooked up. Doing cab wiring and exhaust now. Will be gone for a while but will post when I'm back at it. Hope to get it going this spring.
Bill.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
for sale sv200 snowstorm Snowcat Classifieds (For Sale / Wanted) Forum 12 10-08-2013 01:37 AM
Water in SV200 differential? snowbird Snowcat Repairs, Parts & Problems Forum 2 11-15-2012 10:38 PM
SV200 Up Trailer Ramps? snowbird Snowcat Repairs, Parts & Problems Forum 3 12-31-2011 08:21 PM
WTB: SV200 BEZEL oiltec Snowcat Classifieds (For Sale / Wanted) Forum 1 11-05-2010 11:53 AM
Overheated SV200 snowbird Snowcat Repairs, Parts & Problems Forum 3 01-18-2010 05:34 AM
