Ok Folks I need some help or advice here . I have an mid 80,s model Iseki TA255 that I,m having problems with the front drive axle . Being its japanese & grey market I cant find any info , much less anyone that has any model thats close to it other then one guy at TBN & he seems to have disapeared like most grey market tractor owners .
I haven,t posted this particular problem at Doc,s other site because I never got any replys on the other Chinese YTO I own . All that being said heres the problem .
Awhile back I was digging in some perty hard dirt in 4wd for most of the day & all of a sudden I started getting an odd growling noise that seemed to be coming from the front left wheel . I immediatlly kicked it out of 4wd & all seemed to be fine so I finished moving the dirt in 2wd & put the tractor in the shed .
Untill the other day I just let it sit as I figured I could still use it in 2wd , Well I was wrong . I went to use it & got several feet & the front end kind of locked up for a second & kinda jerked the front wheel to the left . I wanted to move it to my other shop to look into it & it did it several more times but I was at slow speed so it didn,t seem to hurt anything . It will also do it in reverse & makes no difference what gear or 4 or 2wd .
I took the loader off & crippled it into the shop & got it up off of all 4,s & secured on jack stands . I fired it up & slowly tried to see if I could get it to do it going through all gears & different rpm,s & no matter what it seems fine & it doesn,t jerk or make any odd noises , theres no leaks or play in anything that I can tell either .
I beleive its it entirelly a front axle problem & posiblly on one of the outer gear housings since it only appears to do it with the weight of the tractor on it . At first I thought it might be a front ujoint but as far as I can tell there is no such thing . It appears to be a solid shaft that bolts from the main gearbox to the front 3rd member & I have no clue how to even get it off or loose without removing the whole front axle from the tractor . Its completlly different then my newer tractor so the manual for it dont help a bit .
At any rate I,m kind of stuck untill I can figure out if it even has a ujoint Or how the drive shaft works as it appears to be enclosed . I just took some pics that gives an idea of what I,m dealing with & if anyone could steer me in the right direction it would be much appreciated . Sorry for the long post I,m trying to include as much info as posible . Sorry for the tractor being dirty but hopefully you can still get an idea from the pics . Thanks in advance .
