300 6cyl ford fuel injection
mbsieg
awful member
Ok who has put one of the aftermarket fuel injection kits on a 300 6cyl. What manufacture did you use? how did it fit and how did it run? The oem ford does not fit in the orig engine bay on this cat so we are looking at aftermarket system. Help here please.
300 H and H
Some one here on the forum's just did a 300. Might search, and I will to. Maybe they will chime in, if they see this thread.
why efi----not a carb------I have a tucker that was owned by a snowmobile club at one time----they put a jasper reman in it with efi---the only good part is when you start it----no pumping and playing with a choke---it has a low end lean pop that messes with it shifting--and yes I have all sensors in and hooked up---I do like efi----but add on still not sure----take the time to google fuel injection----old school throttle body is way out of date-----I have had 2 cats with a ford 6 in it they were good on gas---one had a points dist. in it---it would start hard when It was below zero out I put a bypass switch on the in line resistor to start it than would switch back after starting---worked like a champ----buy a new carb---pointless dist.----big ass inline fuel filter and run it just sayin
mbsieg
awful member
The reasoning behind efi is the elevation changes. This cat gets used at 4k feet, and 10.5k. But getting good driveability at those altitude changes is proving fun. The carb that was on it was a victim of ethanol and Florida humidity.
samwe
Is the stock manifold aluminum? You might be able to adapt a throttle body to the carb mount and weld in some injector bungs?
TomPa
I have been looking for an answer to the same problems, when going from 6k to 12k the carb just doesn't like the thin air. I ran across these guys and think I might give them a try, kinda pricey but it would be worth it in the long run, peace of mind with a good system goes a long way sometimes. http://www.affordable-fuel-injection.com/
here is an idea----chevy trail blazers are a dime a dozen -----iam a chevy guy but trail blazers are junk----but the motors are great---buy one(the whole truck) --yank the ford motor out drop the trail blazer motor in ---install the wiring and computer and go---you should check with after market co. and see if there mapping will work at 12k----tbi is out dated they sucked when they came out years ago
samwe
I am a Ford guy, but ended up putting a Trailblazer motor in my Muskeg. Nice motor. Lots of power. You should get a wrecked trailblazer so that you have the wiring, then get someone to flash the computer.
You also need to find a 2wd trans. Bellhousings are removable so that makes it easier.
redsqwrl
I was informed the EFI 300 Six doesnt fit into a spryte because the intake runner is so high.
couldn't the air runner just be cut off?
sure you loose a little bit of velocity on the intake air and perhaps some torque would go with it, however the runner could be flanged?
are the injectors near the head?
Just thinking out loud
300 H and H
The plenum is the high point on the Ford EFI manifold. It is actually only a few inches to high I believe. For me the easy way would be to modify the engine cover to gain the extra clearance. The long runner Ford manifold IMHO would be worth the trouble to have in place. That manifold is the best there is on a 300 six.
