Does anyone know what the purpose of this hole is in the crossmember between the two front motor mounts is for? Its slightly bowed up from hitting rough terrain and has vertical cracks along the edge of the drilled out hole. Its naturally a weak point where the hole is. Why is it there? Im going to fix it unless someone has a good reason not to. I would still like to know why someone would do that?
