I'm just in the process of installing complete new tracks on to my spryte. they're 45" wide, 2-5" belts 2-8" belts on each. When I took the old tracks off there were 72 cleats each side with the adjusters backed right off & the tracks so tight they had no slack whatsoever. I ordered the new belts with holes for 74 cleats, thinking I would start with about 73, so that I may have some slack in my tracks. The manual says to run the tracks as loose as possible without the tracks coming off. We don't get much snow here so I'm unsure what to run the track tension at? Also if i use the track hinges I will have to drill 60 holes to mount them, or do I just over lap the belts 3 set of holes , with longer bolts? Your opinions would be appreciated.
