Go Back   Forums Forums - Off Topic Forum FUN > Off Topic Forums > Travel Forum
Travel Forum Check out the "2008 Vacation Posting Contest"
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-26-2015, 05:05 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Default Camera carrier for belt, backpack, bra strap?, etc
Been looking for something to carry a camera, conveniently, and out of the way for a while. My goal was mostly for attaching the camera to a backpack strap, but somethine more flexible would be even better.
I think I found something that will easily work for me, and for anyone else who wants to carry a camera but hates having it hang from their neck.
My goal was to find a system that is:
Lightweight
Mounts on my belt
Mounts on my backpack's shoulder strap
Removes and repositions easily
Doesn't get in the way of the function of a belt or pack
Allows 1 hand to secure the camera in place
Allows 1 hand to remove the camera (this system does NOT do that)
Prevents the camera from "flopping" around while walking
Locks the camera into place securely so it can't fall out of the mount when bending, climbing, sitting, etc.
The "Capture Camera Clip" is the best I have seen, its from a company called Peak Design.
Video of how it works => https://m.youtube.com/watch?v=uPopVxKL3No
__________________
- Ayn Rand
The Following User Says Thank You to Melensdad For This Useful Post:
akmountaineer (04-06-2015)
  #2
Old 03-30-2015, 04:07 PM
Melensdad's Avatar
Default Re: Camera carrier for belt, backpack, bra strap?, etc
It arrived in the mail today.
First off I made a mistake and put it on my backpack without tossing it on the digital scale, so I don't have a weight, but it is very lightweight. Couple of ounces is my guess.
Secondly I'm really impressed by how versitile this is, you can lock the camera into the base in any direction and the base can be screwed down onto just about anything you can get it around (any sort of belt, strap, harness, etc). I bought the cheapest version, with a reinforced plastic backplate and a machined aluminum front plate. The more expensive versions use a machined aluminum backplate instead of the plastic. But the plastic appears to be very strong and solid.
In the box you get the adapter plate that screws into the bottom of your camera's tripod bracket. A hex key to screw the adapter plate into place. A small carry pouch. And the unit itself. Plus instructions. Hardest part to figure out is actually how to unpack it.
Here is the square adapter plate that you screw into the bottom of the camera, along with the hex key wrench. A flathead screwdriver or a coin will also work as the bottom side has a 'slot' too.
Here is the square adapter plate, next to the main part (which is shown in the "open" position). The RED button is the release that unlocks the adapter plate after it is inserted. The BLACK knob on the side is a tension adjustment. The two BLACK knobs on the top are used to clamp the body of the main unit to your belt, pack strap, shoulder strap, etc.
Looking DOWN from my shoulder you can (hopefully) see how it clamps onto my pack strap and how the camera locks into the unit. I moved it around a couple times to find a spot that seemed most comfortable. For now I have it mounted right above the pack's sternum strap.
Slightly out of focus, but you can see how the camera rests tight against the front of my body, it can be angled by simply adjusting the angle of the back plate and clamping it down tight. Not sure, but I may remove the neck strap from the camera?
Here is the ONE downside that I see when used with THIS SPECIFIC camera. . . the door to the battery compartment does not fully open with the adapter plate installed. So at the end of every day the adapter plate has to be removed so the battery can be removed for recharging. Not a huge issue. And clearly other cameras may not have this issue.
__________________
- Ayn Rand
  #3
Old 04-05-2015, 08:57 AM
Melensdad's Avatar
this thing is awesome.
If you use a real camera then you should buy this thing
Tested it yesterday on a hiking trip in North Carolina and I found NOTHING bad and everthing good about this system.
In real life use the camera does not bounce against your body, it was held firmly to my chest strap of my backpack without the big lens banging against me, swaying, bouncing, etc.
In real life use it deploys FAST with a simple push of the red button while you are grabbing the camera. So its all 1 motion, you quickly learn to grab the camera body and press the button and lift it out of the locking position. If you were to fumble a bit the camera would simply stay in the "clip" becuase it is not only locked securely in there but it is also held in by gravity. So dropping it before it is fully removed would end up with the camera re-locking intio place.
It cannot compare in speed to a 'fanny pack' or zippered pouch. My phone rang while we were up there, I had to fumble with the zipper to get it out to answer it just in time before the call went to voice mail. But with this system you can deploy the camera in a SECOND or less. It is that fast.
I intentionally used the heaviest lens I have on this hike, the system held it easily.
__________________
- Ayn Rand
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Backpack Herbicide Sprayers Melensdad Tools & Tractor Implements Forum 5 06-16-2014 09:12 AM
Parents strap kids to roof of car to make room for booze inside the car! Melensdad Food and Drink Forum 10 05-08-2012 03:05 PM
3 belt / 5 belt snow master track layout couchloafer Snowcat Repairs, Parts & Problems Forum 0 12-23-2010 10:42 PM
Snow Trac: busted steering belt! -VARIATOR belt pacifica721 Snowcat Adventure & Usage Forum 4 11-30-2008 04:20 PM
Get em' for you and your kids! A Junkman Backpack! Deadly Sushi Junkman's Corner 0 11-20-2007 11:44 PM
Copyright 2002 - 2020 www.ForumsForums.com
