The dump body on my F450 was getting weaker and weaker. Finally did nothing but click. I went around and tried to wiggle all the electric connections but they all seem good. A friend looked at it with me. We tried jumping out the solenoid and nothing. He says it's toast.
So I order and recieve a new pump kit, get it installed. When I'm getting ready to wire it, the hot wire bangs it and the pump clicks YEAH! Get it wired up and nothing
So I start testing it with a ammeter/voltmeter. There is 12 volts where there is supposed to be but when I take the big, hot cable from the battery and bypass the solinoid, there is no click...no nothing. Finally took some jumper cables and went from the batt. to the pump. Then I used the cables to bypass the circut breaker (nothing) and then went from the cable/circuit breaker to the batt. again and it worked.
Well, the point is, that I really wasn't thinking " bad connection" particularly after getting the same voltage out of the "00" guage wire as the battery had. But there it is
After cleaning the end that goes on the battery, it works.
Now I need to think up something to make out of the old pump
