Got this from Popular Mechanics!
Senior editor Mike Allen (who used to teach organic chemistry in a previous career) gloves up to pump methanol into the processor.
“Make your own diesel for 70 cents a gallon,” the Internet ad claimed. I was tired of paying for 30 gallons of regular diesel each week to fill my pickup, so I downloaded the instructions. It wasn’t long before I was sucking used fry oil out of tanks behind a restaurant, and mixing it with lye and methanol in a 5-gallon bottle before pouring it into an old water heater.
Two hours later, I opened the valve at the bottom of the heater and black goo oozed from the hose, a biodegradable substance called glycerin. Before long the glycerin drained and gave way to a thin, clear, amber liquid: I had my first batch of biodiesel.
I made that first batch of fuel five years ago. If you factor in all the time I spent making the homebuilt biodiesel processor (a converted electric water heater) and experimenting with the design (some batches went, umm, less than perfectly—I had to replace two injection pumps on my truck), my experience with DIY fuels was often a frustrating and, occasionally, very expensive process.
Since then, the biodiesel industry and the technology have evolved. With the professionally engineered biodiesel systems available today, the process is simpler, safer, takes less time and yields more consistent results. So I decided to try one of the commercially available processors—it came boxed with all of the equipment and reagents needed to turn out consistent, high-quality biodiesel fuel. The FuelMeister processor used here has five fewer valves than the eight in my old homemade one. It also mixes the lye and methanol inside the tank to prevent the chance of dangerous spills.
Biodiesel Safety
Yes, you can make biodiesel in a plastic bucket with little more than some drain cleaner, gas-line de-icer and a wooden spoon, if you know what you’re doing. But it can be dangerous. Splashing lye and/or methanol into your eyes can blind you. And electrical pumps unattended in the presence of hundreds of gallons of flammables will make your local fire marshall understandably nervous. In addition, poor-quality product will damage your very expensive diesel-injection pump. Our advice? Research biodiesel production properly before doing the mad-scientist routine.
CONTINUED: http://www.popularmechanics.com/automotive/how_to/4332200.html?page=2
Biodiesel Safety
